Seeking New England USA Z1 mechanic
15 Aug 2010 18:28 #391115 by smurphy777
Seeking New England USA Z1 mechanic was created by smurphy777
Hey Folks,
Picked-up a '74 Z1A back in the Fall - it has not been too kind to me. After the local Kawasaki dealership rebuilt the carbs and tested the electrics, the thing is just not running well. Latest suggestion from said dealership is to do rings. Needless to say it's pricey.
Had an email exchange with a very nice guy at PitstopPerformance in FLA - very far from where I am (NH). You guys probably know him. I am looking to potentially buy new top-end from him but need someone in the area that knows Z1's and can dial this sucker in.
Any tips on a Z1 guy in New England would be HUGELY appreciated.
Best,
Sean
15 Aug 2010 18:59 #391120 by MFolks
Replied by MFolks on topic Seeking New England USA Z1 mechanic
www.z1enterprises.com is run by Jeff Saunders who is based in New York. Contact him and see if he or his company can help.
15 Aug 2010 19:34 #391130 by smurphy777
Replied by smurphy777 on topic Seeking New England USA Z1 mechanic
Thanks Mike, good idea. I have actually exchanged emails with Jeff recently, but did not ask if he knew anyone out this way.
Sean
17 Aug 2010 13:30 #391710 by fixer5000
Replied by fixer5000 on topic Seeking New England USA Z1 mechanic
call these guys. they might be able to set you up
Name: Harry's Machined Parts
Street: 15 Belmont St
Postal address: 01532 Northborough, MA
Phone: (508) 366-1455
1978 kz650b pretty much stock
massachusetts
17 Aug 2010 13:38 #391713 by kawsakiman
Replied by kawsakiman on topic Seeking New England USA Z1 mechanic
i would suggest a compression and leakdown test before you rip the motor apart.
it could be a bunch of different things such as inproper cleaning of the carbs, carbs not synced right, valves out of adjustment, timing out of adjustment just to name a couple.
did they give you a reason why you need rings or are they just guessing?
17 Aug 2010 13:39 #391714 by Jack
Replied by Jack on topic Seeking New England USA Z1 mechanic
Fixer 5000 - good call on Rick Stetson - Harry's Machined Parts. My first choice if I was in that neck of the woods - first class man and work.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
17 Aug 2010 15:22 #391731 by smurphy777
Hey kawasakiman,
Thanks. Here's what they told me:
Compression is 135 and 120 on the two weak cyl (middle cyl's) the leakdown is 11% and 19%. the leakdown is the real cause for concern. as typically anything exceeding 5% is a substantial leak.
Sounds ugly. Still, could be a 'set' of problems, of course, including rings (such as the ones you suggest as possibles).
Regards,
Sean
17 Aug 2010 15:23 #391732 by smurphy777
Fixer and Jack,
Thanks for the recommendation / endorsement. Will check them out. That's not far at all from where I am.
Regards,
Sean
19 Aug 2010 09:08 - 19 Aug 2010 09:11 #392131 by Polar_Bus
Replied by Polar_Bus on topic Seeking New England USA Z1 mechanic
smurphy777 wrote:
Hey Folks,
Best,
Sean
I'm in southern NH as well over by the seacoast. Here's a personal friend that's been a kawasaki tech for the past 25 years. He is the ONLY one I trusted to lay a wrench on my beloved GPz1100 when it had issues beyond my capabilities. He is based in Salisbury, MA. Fantastic guy to deal with, and very reasonable service rates.
Claxton Powersports Repair
142 Lafayette Rd. Salisbury, MA 01952
Rick Claxton
978-961-0475
Bikes:
'84 GPz1100
'06 HD Fatboy
Last edit: 19 Aug 2010 09:11 by Polar_Bus.
19 Aug 2010 15:17 - 19 Aug 2010 15:20 #392205 by GregZ
Replied by GregZ on topic Seeking New England USA Z1 mechanic
You can try the oldkawman,mike Coogan
If you want his number pm me. He is in Swansee Ma.
Last edit: 19 Aug 2010 15:20 by GregZ.
22 Aug 2010 07:09 #392932 by smurphy777
Thanks GregZ - from your lead, found him on the web and dropped him an email.
Much obliged.
Sean
27 Aug 2010 07:57 #394212 by smurphy777
Hey Polar_Bus,
Spoke with Rick - very nice guy. I am going to make arrangments to get the Z1 over to him in the next week or two. Will be good to have someone who's into it taking a reading and getting it dialed-in.
Thanks again.
Sean
