Piston and Cylinder Bore
- Brown Bear
13 Aug 2010 08:38 #390600
by Brown Bear
Piston and Cylinder Bore was created by Brown Bear
the KZ550
Piston OD 57.80mm
Bore 58.10mm
KZ400
piston OD approx 52mm
too much of a difference i think..
Piston OD 57.80mm
Bore 58.10mm
KZ400
- bountyhunter
- Thank you received: 337
13 Aug 2010 11:14 #390655
by bountyhunter
Replied by bountyhunter on topic Piston and Cylinder Bore
Where did you measure piston diameter? They are always narrower at the top and wider at the bottom. I recall at the top where the rings are, there is about a .006" gap to the cylinder wall.
- Brown Bear
13 Aug 2010 12:10 #390667
by Brown Bear
Replied by Brown Bear on topic Piston and Cylinder Bore
not far from the bottom, i also looked in the manual. which says pretty much the same
- steell
13 Aug 2010 12:40 #390676
by steell
Replied by steell on topic Piston and Cylinder Bore
bountyhunter wrote:
And wider measured across the pin than perpendicular to the pin.
Makes for an odd shape piston when you think about it.
Just measured a Wiseco 810 piston to verify.
