- Thank you received: 12
cylinder stud question?
- lewisj
12 Aug 2010 19:57 #390501
by lewisj
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
cylinder stud question? was created by lewisj
This is a really silly question and I'm sure if I look around enough there is a thread on this somewhere, however time is valuable so here it is. I am installing APE cylinder studs. It has been so long since I removed the old ones and I can't remember if the end with the most threads goes into the case or is on top? Any other hints on installing the studs. Lube? Loc-tite? Any help is appreciated and thanks in advance.
Jim
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- APE Jay
- Banned
- Thank you received: 58
12 Aug 2010 21:36 #390517
by APE Jay
Replied by APE Jay on topic cylinder stud question?
If this is a KZ, then there are two different thread pitches. The courser one goes in the case. That should also be the longer one.
- lewisj
13 Aug 2010 06:47 #390583
by lewisj
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Replied by lewisj on topic cylinder stud question?
Thanks Jay! I didn't look close enough, now that I do it's obvious.
Thanks again
Thanks again
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
