Homemade shim change tool?
  • TeK9iNe
  • TeK9iNe's Avatar Topic Author
  • What did you do!?!
12 Aug 2010 12:51
#390367
Somebody stole my Kaw OEM shim change tool from my shop... argh! The other one I have doesnt fit right.
I remember there was a quick way of fitting some zip tie over the valve or something...
any ideas? I have to get this done tonight.
Cheers.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Motor Head
  • Motor Head's Avatar
Re: Homemade shim change tool?
12 Aug 2010 13:53
#390384
How about 2 screw drivers or a couple small pry bars? One to push the valve down, or if you rotate the motor the cam can do it, and one to wedge the edge of the bucket while you change the shim?
You said ANY Ideas.:blink:
12 Aug 2010 15:21
#390405
TeK9iNe wrote:
...I remember there was a quick way of fitting some zip tie over the valve or something....
Might be mistaken, but vaguely recalling a folded zip tie inserted through the spark plug hole and looped around the open valve to prevent the valve from closing into its seat.
Both ends of the zip tie remain outside the spark plug hole.
In other words, using the zip tie to hold the valve open.
Gonna need the right size zip tie.
Good Fortune! :)
  • DFIGPZ
  • DFIGPZ's Avatar
12 Aug 2010 19:38
#390490
Well if it were me i would check the valves and make note of clearances and back off cam chain tensioner and loosen cam caps change shims instead of risking damage prying. but hey i am used to shim under buckets.
1984 750 Turbo
  • Kawickrice
  • Kawickrice's Avatar
12 Aug 2010 23:38
#390529
Here you go it is buried in the tool section.
kzrider.com/index.php?option=com_kunena&...w&catid=21&id=320714
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • TeK9iNe
13 Aug 2010 05:55 - 13 Aug 2010 05:56
#390565
:laugh: :laugh: :laugh:
Obviously, you did not understand the question... I've changed shims a bazzillion times. Its ok.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 13 Aug 2010 05:56 by TeK9iNe.
  • TeK9iNe
13 Aug 2010 06:00
#390566
Thanks Kawickrice! Before even seeing your post thats exactly the tool I came up with last night, and...
it works fantastically! ...and fast!
Just push the valve down into the cylinder with the cam, then wedge the edge of the zip tie up under the valve and roll the cam forward. It leaves a nice enough space to pop the shim out with a dentists pick and small forscepts.
Screw the old tool, this is superfast and in no way damages the valves.
Cheers!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Kawickrice
13 Aug 2010 09:16 - 13 Aug 2010 09:17
#390638
Cheers!
B)
I agree 100% fast, cheap, and easy, kinda like my women's
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
Last edit: 13 Aug 2010 09:17 by Kawickrice.
  • DFIGPZ
  • DFIGPZ's Avatar
13 Aug 2010 16:20
#390703
B)
NO you misunderstood my post i am sure you know how to check valve clearances. I posted i WOULD NOT RISK DAMAGE to the head using a make shift tool. I would just loosen the cam cap lift cam slightly and exchange shim. but everything i always owned had shim under buckets or converted and I had no choice but to use this method.
1984 750 Turbo
