HELP with clutch
- exc3456
11 Aug 2010 21:52 #390262
by exc3456
HELP with clutch was created by exc3456
I have a 77 kz650. When I have it on center stand with the rear wheel off the ground, I pull the clutch in and put it in firt gear, the rear wheel spins with the clutch still pull all the way in. Is that normal, or there's something wrong with the clutch? Do I need adjustment?
- PLUMMEN
- Thank you received: 104
11 Aug 2010 21:59 #390265
by PLUMMEN
Replied by PLUMMEN on topic HELP with clutch
thats normal,if you grab the wheel it should stop
- exc3456
11 Aug 2010 22:00 #390266
by exc3456
Replied by exc3456 on topic HELP with clutch
Thank you very much
- bountyhunter
- Thank you received: 337
12 Aug 2010 00:12 #390284
by bountyhunter
Replied by bountyhunter on topic HELP with clutch
PLUMMEN wrote:
I recommend using the rear brake as opposed to trying to grab the wheel with your hand....:laugh:thats normal,if you grab the wheel it should stop
- TeK9iNe
- What did you do!?!
- Thank you received: 28
12 Aug 2010 06:43 - 12 Aug 2010 06:45 #390314
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic HELP with clutch
bountyhunter wrote:
NAH! Grab it! ... Post pics :silly:
Even with the clutch pulled, there is still liquid friction (oil) between the clutch plates that transfers energy out to the rear. Totally normal, and in fact should be happening.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 12 Aug 2010 06:45 by TeK9iNe.
