Cylinder Boring
  • drmadd95
  • drmadd95's Avatar Topic Author
Cylinder Boring
11 Aug 2010 21:30
#390253
Since the cost of stock 750 rings is about half the cost of the Wiseco 810 kit I opted for the kit. Now I just need to get my cylinders bored out. I'm trying to find a place locally here in Spokane, WA to do it, but wanted to know if everyone here has a particular place to ship their cylinders out and how much does it typically run to do the boring?
Thanks.
1979 KZ650 B (Main Ride)
1978 KZ650 D1 (sold)
1982 KZ750 (parts bike)
  • DFIGPZ
  • DFIGPZ's Avatar
Re: Cylinder Boring
11 Aug 2010 22:08 - 11 Aug 2010 22:16
#390268
Myself i only use "FAST BY GAST" for boring, on a 810 for a 750 you better have it perfect as there is NO room for error as the sleeve is thin when bored to 810. Paul has done a few for me for the 750 turbo applications.
1984 750 Turbo
Last edit: 11 Aug 2010 22:16 by DFIGPZ.
  • bountyhunter
  • bountyhunter's Avatar
Re: Cylinder Boring
11 Aug 2010 22:37
#390274
I think it was $60/hole for boring at the shop I went to here. Ask one of the wrench turners at a local dealer who they use to do their machine work and you should get a good one.
  • otakar
  • otakar's Avatar
Re: Cylinder Boring
12 Aug 2010 06:25 - 12 Aug 2010 06:28
#390308
I ONLY use Pit Stop Performance. Joe charges only $125 for the block and the postage is not that much if you send it FedEx Ground which is what I use. Joe advertises on this web sight and I find him to be one of the best in the business and the cheapest.
www.pitstopperformance.com/
He has done three blocks for me including a KZ1300 block. He only recently raised his prices from $100 to $125 per block which still no one can match. FedEx ground usually only costs me about $16 from Chicago.
www.pitstopperformance.com/cylinder-bori...and-honing-c-2_17_67
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 12 Aug 2010 06:28 by otakar.
  • otakar
  • otakar's Avatar
Re: Cylinder Boring
12 Aug 2010 06:32
#390310
Here in the Chicago area most shops are around $80 a hole and some are as much as $100 a hole. But even at the $6o per hole it comes to $240, which is twice of what Joe Hooper charges at "Pit Stop".
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Cylinder Boring
12 Aug 2010 06:34
#390311
Have to agree with Otto here. I've heard good things and prices are very competative.
GL.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • otakar
  • otakar's Avatar
Re: Cylinder Boring
12 Aug 2010 06:59 - 12 Aug 2010 07:00
#390316
When I had My block bored for the GPz1150 Joe even took care of having the custom pistons made at MTC. I guess his shop is only a few miles from MTC and he has a good rapport with them. He will bend over backwards to make you happy.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 12 Aug 2010 07:00 by otakar.
  • APE Jay
  • APE Jay's Avatar
Re: Cylinder Boring
12 Aug 2010 12:49
#390366
  • drmadd95
Re: Cylinder Boring
12 Aug 2010 13:14
#390376
Thanks for all the input! Just waiting on my pistons to come in the mail now.
  • steell
  • steell's Avatar
Re: Cylinder Boring
12 Aug 2010 13:46
#390381
If all you want is "good enough" then any of the places listed can do it. If maximum ring seal and ring life is your goal, then there are a lot fewer places that can do it.
Educate yourself, do a search for "cylinder honing" then you'll know the questions to ask.
  • fordtruck
  • fordtruck's Avatar
Re: Cylinder Boring
12 Aug 2010 22:34
#390522
I had Joe bore my cylinder plus rebuild my cylinder head. I now have over 2k miles on the motor and I'm very happy with his work.
'77 KZ1000-MTC 1075 kit. Stage 1 port
