Lost performance after rainstorm
- Soulmighty
10 Aug 2010 17:09 #389961
by Soulmighty
Lost performance after rainstorm was created by Soulmighty
Hi everyone,
I have the strangest problem with my Z1. I just finished restoring/customizing a Z1 Classic that had been running great. However, during a rainstorm I noticed the bike begin to sputter and not run right at all. I had been experiencing an oil leak (slight) from the #1 cyl just under the Cam cover.
When I got it home it didn't appear that #1 cyl was working at all and when I restarted it and began to rev the motor, oil started to push up through the cam cover caps over the #1 cyl (even through the screws holding the cam cover cap down). Do I have water in the engine? Can someone tell me what has happened???
Help!
Help!
- Jeff.Saunders
10 Aug 2010 17:38 #389963
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic Lost performance after rainstorm
More info needed...
Are you running pod filters?
Are you still running EFI or carbs?
What else has been done with the bike?
Z1 Ent on Facebook,
- moneypit
- Thank you received: 35
10 Aug 2010 17:40 #389964
by moneypit
2-76 kz900
St Paul MN
Replied by moneypit on topic Lost performance after rainstorm
only thing I can think of for poor running is does it have pods if they get wet it chocks the engine GL
2-76 kz900
St Paul MN
- TerryK
10 Aug 2010 17:44 #389965
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Lost performance after rainstorm
Wet ignition for the bad cylinder, leaky valve cover could be a number of things.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- jeffasaki
- Thank you received: 44
10 Aug 2010 18:00 #389971
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Replied by jeffasaki on topic Lost performance after rainstorm
Had the same problem with one of my bikes.Had a chopped down front fender and was throwing water up at the coils whenever it was wet.Took off the tank sealed up all the connectors under and installed a unmodifed front fender that kept the water out,Never happened again.And ive rode through some pretty bad rainstorms since.Ill add that Im runnig pods and if its really comming down I just pull my knees in to offer the carbs some protection from wind and rain.
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Soulmighty
10 Aug 2010 18:02 #389974
by Soulmighty
Replied by Soulmighty on topic Lost performance after rainstorm
Hey guys,
Thanks for the responses! The bike has been converted to carbs and does have pods. When I checked the #1 cyl when I got home it was much cooler than the other 3. When I restarted the engine to see if I could see or hear anything weird, the #1 header pipe again was much cooler than the rest. As I began to rev the engine, I noticed much more oil than the usual tiny leak begin to pour pout of the top an sides of the cam cover and the cam cover caps.
Did I lose compression in #1? Obviously it seems to have some directly to do with the rain. I know that I need to replace the gasket for the cam/valve cover so I am going to start there. Any other suggestions?
Thanks!
Thanks!
- Motor Head
- Thank you received: 391
10 Aug 2010 18:39 #389980
by Motor Head
Replied by Motor Head on topic Lost performance after rainstorm
Like Money pit said, engine could have Hydro-locked, damaging a piston. Pistons are meant to compress fuel & air, not water. Make sure to do a compression test.
- moneypit
10 Aug 2010 18:53 #389982
by moneypit
2-76 kz900
St Paul MN
Check your oil too. if number 1 wasnt firing, the fuel may have bypassed the rings into the crankcase, hense more oil, more oil pressure, thus more oil leakage. GL
2-76 kz900
St Paul MN
- Soulmighty
10 Aug 2010 18:59 #389983
by Soulmighty
Well.. thanks again for all of this great info guys. I let the bike dry off and started it and everything seems fine now. Looks like it was a wet ignition so far. Looks like Terry and Jeffasaki's info is correct (for now). Will recheck in the morning.
Thanks again everyone! You guys are grrrreat!
My Z1 thanks you!
My Z1 thanks you!
- Capt America
- Born Bad
- Thank you received: 1
11 Aug 2010 23:23 #390282
by Capt America
Capt A merica
1983 K1 750 twin
Ontario, Canada.
Replied by Capt America on topic Lost performance after rainstorm
I love the bike, very nicely done, and the color scheme is fantastic. Very pretty girl.
So your pods dried out, and whatever water was in your bowls evaporated. Awesome, aren't pods fun in the rain, grin.
Capt A merica
1983 K1 750 twin
Ontario, Canada.
- kawasakibikefan
- Riding is a passion most do not understand.
12 Aug 2010 06:05 #390305
by kawasakibikefan
'75 Z1B
'95 KLR250
My Future Buying List:
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
Replied by kawasakibikefan on topic Lost performance after rainstorm
Might be time for new spark plug leads.
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
- Soulmighty
12 Aug 2010 06:53 #390315
by Soulmighty
Thanks Capt.! It might interest you that the paint is actually black with gold pearl but the pearl is very lightly done so it looks like metalflake.
As for the engine prob in the rain, I have confirmed that the ignition was getting wet and that's why the engine started running like a cow with a flatulence problem.
It's running great now.
Hope everyone is having a great day!
