Does heat and high humidity affect the engine?
- smørbrød
I have a 1981 kz550 ltd. Up until this heatwave in minneapolis the bike was running fine. I didn't have time to ride it for maybe four weeks. Now it won't start, it just turns over. Is there any chance that 95 degree weather and high humidity would affect that?
Thanks,
Joel
- Nebr_Rex
- Thank you received: 300
Hello All:
Thanks,
Joel
No it shouldn't.
Check the basics,fuel,spark,compression.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- smørbrød
- JMKZHI
- Thank you received: 48
- Old Man Rock
- Thank you received: 225
When you say it turns over, does it seem slower then usual?
We face this here in AZ where these type of batteries just don't last here and I'm not just talking motorcycles. Any battery, don't care what kind or who makes it... THEY DON'T LIKE HEAT....
They can deal with the cold just fine but heat, kills them like an ex-wife does to ya.... :blink: :laugh:
If you have this type of battery, look at the posts, all white (acid paste/chalky), corroded etc...
Check your battery voltage.... Clean the terminals and charge up....
Also, doesn't your model have engine start inter lock switches and such.... If so, may want to confirm those are operating correctly as well....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- smørbrød
- stardon
- Thank you received: 5
- smørbrød
