HELP STARTER WONT ENGAGE
- andrew1980csr650
12 Apr 2006 10:55
my starter wont engage everytime actuley wont engage most of the time what do i need to do starter just spins i know there is a 1 way clutch or something in there but is there an easy fix
thanks andrew
thanks andrew
- KLACKO
Re: HELP STARTER WONT ENGAGE
12 Apr 2006 11:02
Sorry, Andrew... no easy fix for fixing the starter clutch. At least the parts are cheap.
OnkelB put up this thread: kzrider.com/forum/viewthread.php?tid=9285
and this one:
kzrider.com/forum/viewthread.php?tid=9186
Thanks, Bo... [how are those plungers doing?]
Post edited by: klacko, at: 2006/04/12 14:10
Post edited by: klacko, at: 2006/04/12 14:11
and this one:
- andrew1980csr650
12 Apr 2006 12:19
SO my bike just goes zing and no crank is this my problem this really sucks because i just got the f?@#ing whole bike back together inc the motor damn
thanks andrew:angry:
- andrew1980csr650
12 Apr 2006 12:41
think i need to update my sig this is a 1000j motor sorry but thanks for the help i spoke to jeff great guy i might ad and he gave me some tips thanks again
andrew
andrew
- KLACKO
12 Apr 2006 14:17
andrew1980csr650 wrote:
Maybe you need to update your username too...:blink:
andrew
- RomSpaceKnight
12 Apr 2006 16:30
At least the 100 has starter on end of crank not off primary drive like 650.
- OnkelB
12 Apr 2006 16:58
KLACKO wrote:
Hi Kris - they´re doing alright, starts right up most of the time though I still get the occasional oogah squeal Most likely the starter clutch gear acting up, the surface where it contacts the rollers wears out of round and develops flat spots over time, hence the occasional miss.
77 KZ 650 B1, 82 GPz 1100 B2.
- andrew1980csr650
13 Apr 2006 05:31
THANKS JEFF
you were right it came loose removed it cleaned all and tightened it up all is good now thanks again and im gonna update my name going for streetfighterkid hopeits avail
- KLACKO
13 Apr 2006 06:14
Just don't pick "bikerkid"...
THANKS JEFF
- Sandy
- Fly High,Tony
13 Apr 2006 07:55
Did You happen to notice what shape the woodruff-key was in,on the end of the crankshaft?
I had a similar problem,and it was the key that had snapped...starter WAS turning over,but it was only spinning the rotor on the crank...
I'm pretty sure that the "J" motor has a key,as well as a tapered fit?...
1977 KZ1000 A-1
- kano
- Not Another Bloody Limey!
14 Mar 2007 12:00
i am having the same problem every now and then my starter doesn't engage and makes a rather horrible noise,
did a search ended up with some dead links to archives,
can someone enlighten me to how the starter engages when its superposed too so i can look into the cause,
rough sketch or details would be great.
thx.
thx.
- kano
17 Mar 2007 11:27
dam my starter is making a nasty noise again not sure why,
im going to try to check all the wiring once ive warmed up a bit.
but it dosnt do it all the time mostly it fires right up, then for no reason back comes the wining turn over...
anyone had this happen to them?
