KZ750 upgrading to 810 question
- drmadd95
08 Aug 2010 16:18 #389400
by drmadd95
1979 KZ650 B (Main Ride)
1978 KZ650 D1 (sold)
1982 KZ750 (parts bike)
KZ750 upgrading to 810 question was created by drmadd95
So I'm working on an 82 kz750 motor to replace my 650 motor and after I got the starter clutch repaired I checked the compression and found that two of the cylinders were very low (right around 100 psi). Anyway I'm tearing the whole top end off including the cylinders so I can replace all the gasekets and o-rings.
I found the reason for the low compression in the cylinders. Apparently this motor sat for awhile and there is some pitting in the cylinders. I'm taking it to get looked at to see if honing and re-ringing will fix the issue. If I have to bore it out to put in oversized pistons then I'm going to just get the 810 kit to install.
Do you guys think I should just go ahead and put in the 810 kit since I've got it all apart? The rest of the motor is stock and I didn't plan on upgrading anything else as far as the cams, head, or carbs. Will just putting in the 810 kit without doing anything else really wake up this motor or am I just wasting my money without the other upgrades?
Thanks in advance.
Thanks in advance.
- T_Dub
- Thank you received: 25
08 Aug 2010 17:56 #389452
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic KZ750 upgrading to 810 question
If you have BS34 carbs, then you'll need a dynojet stage 3 kit just to get enough fuel into it. Other than that, you can do nothing else and still get a big bump in power.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- DFIGPZ
- Thank you received: 122
08 Aug 2010 22:01 #389524
by DFIGPZ
1984 750 Turbo
Replied by DFIGPZ on topic KZ750 upgrading to 810 question
Yes a stage 3 carb recalibration kit gpz750 cams would go nice with that combo but not ness.
1984 750 Turbo
- drmadd95
08 Aug 2010 22:43 #389531
by drmadd95
Replied by drmadd95 on topic KZ750 upgrading to 810 question
I have the Keihin CV34 carbs that came with the 750 motor I'm working on. To be honest I'm not sure which Mikuni carbs I have on my 650 right now. I think they are the VM34 if that is what came stock on it.
- mark1122
- Keep twisting it
- Thank you received: 109
09 Aug 2010 13:42 #389654
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic KZ750 upgrading to 810 question
more cc's alone will give u more torque down low. larger cams ,carbs, and porting will move the power up in the rpm range. Generaly speeking.
The cv34's should be plenty.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
