not firing on piston 1 and 2
- JARHEAD76
07 Aug 2010 13:52 #388992
by JARHEAD76
not firing on piston 1 and 2 was created by JARHEAD76
Hi guys, have a 1983 spectre kz1100, cleaned the carbs, but didnt take out the main jet just blew it out. Didnt know how till I asked on here and had it put together. Now the bike is only running on 3 and 4 cylinders. 1 AND 2 are not working. Pulled out spark plugs and they are firing but the pipes are only warm not hot like 3and4. Dont know what it originally did because it was so filthy I cleaned first. Help appreciated thanks
- DFIGPZ
- Thank you received: 122
07 Aug 2010 19:02 #389156
by DFIGPZ
1984 750 Turbo
Replied by DFIGPZ on topic not firing on piston 1 and 2
Remove your carbs again and clean all passages and pilot jets for sure sounds like 1 and 2 pilots may be clogged.
1984 750 Turbo
- PLUMMEN
- Thank you received: 104
07 Aug 2010 19:12 #389174
by PLUMMEN
Replied by PLUMMEN on topic not firing on piston 1 and 2
soak/scrub carbs,a can of sea foam in the tank does wonders also if you can take it out and put a few miles on it
