- Thank you received: 12
APE cam chain tensioner
- apbling
05 Aug 2010 10:47 #388374
by apbling
APE cam chain tensioner was created by apbling
What do people think about the APE cam chain tensioners. I am thinking about buy them form my 550 and 750, but they seem a little high priced...
When you tighten them down, how do you know how tight to adjust them? Is there a torque spec?
- dshelly
- Thank you received: 5
05 Aug 2010 11:34 #388386
by dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Replied by dshelly on topic APE cam chain tensioner
You can get the same thing on ebay for about $15 less and it has a new gasket with it. I think the one for the 900's will fit the 750 you have ,that is if it's a 4 cyl. The 550 is different though. The APE ones are alright, I have 3 of the ebay ones on my bikes and they work great.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- otakar
05 Aug 2010 11:34 #388387
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic APE cam chain tensioner
If you search for that item in the sight search engine you will find that there is a plethora of threads on this subject. If you don't like the APE here is a link for a different one.
www.americanclassix.com/kawa_improvements.html
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Jack
- Thank you received: 7
05 Aug 2010 11:43 #388388
by Jack
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Replied by Jack on topic APE cam chain tensioner
Finger tight seems to work best on 900/1000 motors.I overtightend the first one I bought and the camchain ate the rubber roller in front of the adjuster. Found it all in the oil pan...
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- otakar
05 Aug 2010 15:24 #388426
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
When I called APE about it they told me "finger tight, and back off 1/4 turn" Engine must be at TDC.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- MFolks
- Thank you received: 540
05 Aug 2010 18:12 #388472
by MFolks
Replied by MFolks on topic APE cam chain tensioner
Another tensioner:
www.kriegercamchaintensioners.com/
- hocbj23
- Visitor
05 Aug 2010 18:35 #388482
by hocbj23
Replied by hocbj23 on topic APE cam chain tensioner
otakar wrote:
x2When I called APE about it they told me "finger tight, and back off 1/4 turn" Engine must be at TDC.
