X-pipe the ultimate exhaust???? ADD!
  • Splandman
  • Splandman's Avatar
Re: X-pipe the ultimate exhaust???? ADD!
07 Aug 2010 10:49
#388946
No eBay APP ID and/or Cert ID defined in Kunena configurationHere's a Murray X on ebay for Suzuki
Current Bikes
1980 KZ1000E
  • nads.com
  • nads.com's Avatar
08 Aug 2010 01:55
#389235
porchev914 wrote:
steell wrote:
porchev914 wrote:
I always though oxygen was the source of power, the more oxygen you can burn the more power you make. A pipe that doesn't flow enough additional air to require rejetting is not, in my mind, a pipe that would dramatically increase power. I don't believe his claims at all...a whole lotta hype with very vague claims from customers....
Can Murray make his pipes out of stainless? And would it clear a monoshock linkage? If so, I may be interested...
My only disagreement with your post is the part about oxygen burning, it don't.
Oxygen is a catalyst that allows other stuff (known as fuel) to burn. Take a oxy/acetylene torch, turn on the oxygen while leaving the acetylene off and try and light it.
Fuel reacts with oxygen to create combustion. Oxygen combines with iron to create iron oxide, AKA rust. Just thought I'd throw that one out there :)[/quotej]
Why would you feel the need to disagree with my poorly phrased statement? Your statement is simply the reverse of my original post. Oxygen without fuel is just as worthless as fuel without oxygen. Turn on that same acetylene torch without oxygen and you get.....nothing. I did not feel a tutorial on the basic dynamics of fuel combustion was required to make the simple statement that the difficulty of making more power is getting more oxygen into the engine. My statement was in context to the thread, referencing an exhaust system, which to the best of ymy knowledge does not introduce extra catalyst, but does have a direct bearing on the oxygen available for combustion. I simply take exception to you using my post to talk to the readers of this tread like we're morons.
This is very serious stuff, meow! someone threw a rock at the cat!:woohoo:
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
14 Sep 2010 12:05
#398662
When I first rebuilt my MKII (1229cc) back in the early 90's I was having a hard time finding a pipe that I really liked. I tried a Denco, an RC, a Supertrapp, a V&H and finally got to try out a Campbell X-pipe. It was the one with the "MX-3" in red on the canisters. Anyway, that thing did run well but I just couldn't get past the sound. It was just too different for me. Didn't get to run it on the dyno but it seemed to make a lot of power throughout the rpm range. I finally settled on a plain old cheap chrome V&H 4-into-1. It was only $240 at the time and the quality was good back then.
The Kaw List:
  • MGK612
  • MGK612's Avatar
15 Jun 2019 01:12
#805743
I can't see the picture now, but any chance you'd be willing to sell that X-Pipe??
1977 KZ1000 LTD
Minneapolis/Tokyo
  • TexasKZ
  • TexasKZ's Avatar
15 Jun 2019 09:55 - 15 Jun 2019 09:58
#805767
MGK 612, the most recent post in this thread was made in September 2010.
Perhaps you should contact Murray to see if they still make the system.
murrayexhaust.com/index.htm
You can also give Campbell a call.
x-pipe.com/japanese.html
Last edit: 15 Jun 2019 09:58 by TexasKZ.
The following user(s) said Thank You: Nessism, MGK612
  • TexasKZ
  • TexasKZ's Avatar
15 Jun 2019 13:14
#805776
You might want to consider this as well.
kzrider.com/forum/2-engine/592300-kz1000-kerker-exhaust
The following user(s) said Thank You: MGK612
  • MGK612
  • MGK612's Avatar
17 Jun 2019 05:56
#805909
TexasKZ wrote: You might want to consider this as well.
Thank you! I was really just hoping to score one of these Campbell Pipes for my KZ1000, only to realize the guy that said it was hanging in his garage had it for a 650, and not a 1000.
Sorry, I was super tired when I wrote a lot of my first posts. And of course trying to get a feel for the forum. Will make sure to comment/post in newer stuff!
Thanks!
1977 KZ1000 LTD
Minneapolis/Tokyo
