1977 KZ-650C1 performance parts
- Cookie1893
- Alex Cook
1977 KZ-650 total motor rebuild project
Hopefully after I get the girl running she will fit on the back of a go-cart.... Betcha never saw that one comin!
- Thank you received: 2829
- anarki650
- Thank you received: 5
All those parts will be readily available on ebay without spending a ton of money. Other than those bits you can get into having head work done (I hear great things about Larry Cavannah (sorry if I spelled that wrong Larry) and of course there's no replacement for displacement. If you're having to build a whole motor anyway why not try to source a kz750 motor instead? Just a thought.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- Cookie1893
- Alex Cook
- anarki650
09 Kawasaki ER6n
Omaha NE
- Cookie1893
- Alex Cook
- anarki650
09 Kawasaki ER6n
Omaha NE
- Cookie1893
- Alex Cook
- Cookie1893
- Alex Cook
- steell
Some of the 1980 kz750 4 cylinders used the same cam chain set up as the early 650 motors. Part of the way through 80 they must have ran out of the old parts and switched to the hyvo cam chains that were used in the 81 and newer 650 and 750 motors. Some of the 80 750 cams will have the earlier link style sprockets, and some will have the later hyvo style sprockets on the cams. You can easily swap the sprockets off the 650 cams onto the 750 cams if you do find a set that are for the hyvo chain, just be careful that you're lining up all the timing marks appropriately when swapping the cams.
Have you ever actually seen a real 750 four motor with KZ750E stamped on the case, that had a roller cam chain?
Or are you basing this on previous discussions of what 750 cylinder blocks and heads will work with the 650 roller cam chain?
I have a 750E manufactured 8/79 that has the HyVo style cam chain, and I've never seen or heard of any 750 four having a roller cam chain. And kawasaki.com only lists the HyVo style sprockets and chain for 80 KZ750E1 and KZ750H1.
Not a big deal to swap the sprockets though, and as far as I can tell, the 80-82 (at least) E and H cylinder heads and blocks have provisions for the 650 roller cam chain.
- steell
Also do all gpz750 cams fit? Does it have to be a specific year or do they all fit?
That's the $64k question
MegaCycle says that some 83-85 GPz750 cams have a smaller base circle (would require much thicker shims) than others.
I've had 8-10 sets of 83-85 GPz750 cams, and they have all had the same base circle as 650/750 cams.
Might be some out there, I just haven't run across them.
- Cookie1893
- Alex Cook
