KZ650 overheating, in saint john, NB
- fd2003
04 Aug 2010 15:06 #388181
by fd2003
KZ650 overheating, in saint john, NB was created by fd2003
I have a kz650 which i have put a ltd750 bottom end and a gpz750 top end. I have a dyna s ignition, when I drive around town it overheats but on the highway its fine. I have an oil cooler on the bike, the plugs are a light tan and the timing is right on the money, any suggestions.
- anarki650
- Thank you received: 5
04 Aug 2010 15:35 #388191
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic KZ650 overheating, in saint john, NB
If it's overheating it's got to be lean. The fact that it's overheating around town indicates that lean condition is occurring before the higher rpm ranges of highway speed. I'd try raising the needle one step on the carbs and see if it doesn't cure your woes.
09 Kawasaki ER6n
Omaha NE
- larrycavan
- Visitor
04 Aug 2010 16:19 #388201
by larrycavan
Replied by larrycavan on topic KZ650 overheating, in saint john, NB
fd2003 wrote:
How are you determining that it's overheating?
- fd2003
04 Aug 2010 18:34 #388238
by fd2003
Replied by fd2003 on topic KZ650 overheating, in saint john, NB
when i drive for awhile it starts to run rough, then when i shut it off i cant kick it over, sometimes it kicks back on me.
- Old Man Rock
- Thank you received: 225
04 Aug 2010 18:41 #388241
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic KZ650 overheating, in saint john, NB
Oil pressure to spec at low rpm?
Increased rpm equates to increased pressure...
Highway run equates to increased air flow over the engine... Same principle in running your engine in the garage... Need a cooling fan aimed at her....
Runs rough which way?
i.e. loss of power, misses in the ignition timing, pipes glowing red or more of electrical where coils/rectifier/regulator may be breaking down a tad....
Just a thought...
Just a thought...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- AlienTech
04 Aug 2010 19:33 #388247
by AlienTech
1976 KZ900
Replied by AlienTech on topic KZ650 overheating, in saint john, NB
didn't think anything could run hot in the Fog City
1976 KZ900
- PLUMMEN
- Thank you received: 104
04 Aug 2010 19:37 #388249
by PLUMMEN
Replied by PLUMMEN on topic KZ650 overheating, in saint john, NB
all right where is saint john? :laugh:
