Proper Rpm at 70 MPH? ('81 kz750H ltd)
- jonnygorman
03 Aug 2010 14:38 #387932
by jonnygorman
Proper Rpm at 70 MPH? ('81 kz750H ltd) was created by jonnygorman
Had my 750 out on the road up around 55 in 5th gear. This is my first bigger bike and she sounded like I needed a 6th gear around that speed. I opened the throttle a little more and things sounded a little better at that speed. My tach wasn't hooked up then, and I am planning on going for a ride tonight now that my tach is hooked up. Any idea what rpm I should be running aroung 65 or 70? I just don't want to blow anything up.........yet.
Thanks
Jon
Thanks
Jon
- mjg15
03 Aug 2010 15:10 #387945
by mjg15
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
Replied by mjg15 on topic Proper Rpm at 70 MPH? ('81 kz750H ltd)
5000, maybe a couple hundred more @ 70
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- Motor Head
- Thank you received: 391
03 Aug 2010 15:54 #387950
by Motor Head
Replied by Motor Head on topic Proper Rpm at 70 MPH? ('81 kz750H ltd)
I would say 4300RPM, If much higher you should check you sprocket teeth count and tire sizes against stock. You could gear it up 1 tooth on the front sprocket for $20 or so. But your chain and rear sprocket must be in near new condition. Rear sprocket could go down in size a couple of teeth, if you get a new set you can change the gearing to suit your riding style/ conditions.
- JR
- Thank you received: 448
03 Aug 2010 16:48 #387965
by JR
Replied by JR on topic Proper Rpm at 70 MPH? ('81 kz750H ltd)
5,000rpm @ 60mph and about 6,000 rpm @ 70. If all is well ou get used to it and eventually feel the bike is just humming along nicely at those rpm levels
Cant remember how many teeth on either of my sprockets.
Trying to upshift from 5th to that elusive 6th is something a lot of us do on occasion
- bountyhunter
- Thank you received: 337
03 Aug 2010 18:10 - 03 Aug 2010 18:10 #387983
by bountyhunter
Replied by bountyhunter on topic Proper Rpm at 70 MPH? ('81 kz750H ltd)
On a stock 750 twin, it turns 5000 RPM at 70 mph. This leads many to lower the gear ratios for cruising.
Last edit: 03 Aug 2010 18:10 by bountyhunter.
- MFolks
- Thank you received: 540
03 Aug 2010 18:15 #387986
by MFolks
Replied by MFolks on topic Proper Rpm at 70 MPH? ('81 kz750H ltd)
When changing sprocket ratio's, I use
www.gearingcommander.com
It figures in tire sizes too.
- jonnygorman
04 Aug 2010 05:58 #388060
by jonnygorman
Replied by jonnygorman on topic Proper Rpm at 70 MPH? ('81 kz750H ltd)
Thanks guys. Great Help.
Jon
Jon
- apbling
- Thank you received: 12
04 Aug 2010 06:38 #388066
by apbling
Replied by apbling on topic Proper Rpm at 70 MPH? ('81 kz750H ltd)
+1 for JR. I witnessed this this morning. First time I took my '80 750 on the 4 lane and she hummed along at 70 just a hair below 6k. I have a 550 that has a 6 speed tranny, so I find myself constantly going for that 6th gear!
BTW, if you still have the stock chain/sprockets (630), I parts are quite a bit more expensive than the newer, smaller chain (530) people usually switch to. I'm still running the old, heavy 630, but when it's shot I'm gonna go to the 530.
- djturnz
06 Aug 2010 03:59 #388567
by djturnz
1982 KZ750 (4) LTD
Replied by djturnz on topic Proper Rpm at 70 MPH? ('81 kz750H ltd)
I needed rear sprocket and chain for inspection, so I just did the whole 530 conversion from Z1. I think it was like $130. I also went up a tooth in the front, but I am thinking of going back to stock ratio.
1982 KZ750 (4) LTD
- havakaw
- Thank you received: 27
23 Aug 2010 17:40 #393311
by havakaw
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
Replied by havakaw on topic Proper Rpm at 70 MPH? ('81 kz750H ltd)
On my '80 model,I'm pulling 5500 at 70 mph.Stock gearing,sprockets and chain.Yes,I still look for 6th gear too,and I've had the bike for 5 years now.
'80 KZ 750 LTD-H
- steell
24 Aug 2010 20:15 #393626
by steell
Replied by steell on topic Proper Rpm at 70 MPH? ('81 kz750H ltd)
Well, put a 550 six speed trans in it and you'll have your sixth gear!
But then you'll be looking for seventh :laugh:
