Rough start after sitting over night
- disgustipated
03 Aug 2010 07:21 - 03 Aug 2010 07:22 #387875
by disgustipated
Rough start after sitting over night was created by disgustipated
Hey there, got my first question/issue. For the past couple days this beast has not wanted to start after sitting over night or even while im at work for an 8hr day, and when it does it idle's rough and even sounds like it's "dieseling" after it warms up and i ride it, sounds great, and i can kill it and i'll fire right back up with no problems and no sounds. Sorry for my ignorance and newbienicity, but I suppose this is how one learns. :side:
Last edit: 03 Aug 2010 07:22 by disgustipated.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
03 Aug 2010 07:50 - 03 Aug 2010 07:50 #387880
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Rough start after sitting over night
Welcome!
Well, easy stuff first
Changed the oil lately?
If you have a carburetion issue a can of SeaFoam from NAPA dumped in the tank can make a big improvement.
Part of regular maintenence with these old bikes is a regular compression check, and valve clearance adjustments yearly. Have these been done?, as these are most critical to a smoothly operating engine.
Best purchase you can make is the kaw service manual.
GL!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 03 Aug 2010 07:50 by TeK9iNe.
- cobura
- forever 2 wheels
- Thank you received: 3
03 Aug 2010 09:08 #387892
by cobura
1979 KZ650B3
Replied by cobura on topic Rough start after sitting over night
Sounds similar to a problem i was having before. It could be a very slow leaking float valve. That was my problem, if i let the bike sit for a day, it would be difficult to start again, however once i got it started it ran great and didnt give me any trouble until after sitting a while. After trying to start the bike, if it doesnt start up easily, check the plugs. If one of your plugs is very wet, it could be your problem. Its common for a very very small piece of dirt or grime to fall into your float valve and prevent it from closing. Keep in mind though, there's a lot of things that could be wrong, im just throwing out a suggestion.
1979 KZ650B3
- MFolks
- Thank you received: 540
03 Aug 2010 09:15 #387896
by MFolks
Replied by MFolks on topic Rough start after sitting over night
Ignition points or electronic ignition? Carbs or Fuel Injection? Both systems can benefit from cleaning the many and varied electrical connectors.
For the most part, the connectors are open at the back, letting moisture get in to corrode the male and female "Pins". Don't forget the left and right handle bar switches as they get dirty/corroded too.
I've stated before,I use a brand of electrical contact cleaner/preservative called "De-oxit" on my bike,car,and around the house to remove corrosion and improve electrical contact. www.deoxit.com is their website.
It's available in the U.S. at Radio Shack stores and electronic supply places.
Also a fresh set of sparkplugs properly gapped,new sparkplug caps and possibly sparkplug wires(our friends to the north and the Brits call them "High Tension Leads").
- bountyhunter
- Thank you received: 337
03 Aug 2010 11:22 #387909
by bountyhunter
Replied by bountyhunter on topic Rough start after sitting over night
My guess was going to be gas flooding due to float/needles not sealing. Does your petcock shut off well when you park it?
- Motor Head
- Thank you received: 391
03 Aug 2010 16:00 #387953
by Motor Head
Replied by Motor Head on topic Rough start after sitting over night
You should tell everyone about your bike, and add it to your Signature. Sound like you will be checking for air leaks at the intake and pulling and thoroughly cleaning your carb's, making sure your Ignition is in good shape, then performing a carb sync. Make sure you clean those carb's really good and put an in-line filter in place.
