'78 KZ1000 A2A: Part Identification
- Kawifan
01 Aug 2010 19:15 #387548
by Kawifan
1978 KZ1000 A2A
'78 KZ1000 A2A: Part Identification was created by Kawifan
Hello,
I was wondering if anyone on here could help identify cams for me. I purchased my new-to-me KZ 2 years ago and literally only had time to start tearing into it for maintenance, recently. I'm checking valve clearance and notice "Made In USA" stamped on the cams. So my curiosity is piqued and I notice "CWC EP14" stamped on the cams. I also see 108 stamped on them a well. I'm trying to figure out what I've got with this bike. The previous owner said it was bored to 1050 (he thinks!?!). That will take a bit more to verify, but I'm trying to understand how radical these cams are (or not) as I'm troubleshooting a low-end/idle stumble. Which leads me to the carbs...they look like the standard Mikuni variety, though I'm not 100% familiar with the model as I admittedly have only dealt with Keihin (flatslides and CV's). They need to be rebuilt, but I was pleasantly surprised with a Dyna S ignition and a Kerker 4-1 pipe (though the muffler had been mangled by the previous owner...GRRRRRR). I'll take any leads on new or very clean used (black) Kerker muffler if anyone has one?
Thanks, Ryan
Thanks, Ryan
1978 KZ1000 A2A
- PLUMMEN
- Thank you received: 104
01 Aug 2010 19:19 #387550
by PLUMMEN
Replied by PLUMMEN on topic '78 KZ1000 A2A: Part Identification
picture?
- TerryK
- Thank you received: 3
01 Aug 2010 19:21 - 01 Aug 2010 19:23 #387551
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic '78 KZ1000 A2A: Part Identification
CWC is the cam blank manufacture. EP14 is a Kawasaki KZ blank. The 108 is the lobe center.
Should be a grind number stamped on the ends of the cams.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Last edit: 01 Aug 2010 19:23 by TerryK.
- Kawifan
01 Aug 2010 19:45 #387555
by Kawifan
1978 KZ1000 A2A
Replied by Kawifan on topic '78 KZ1000 A2A: Part Identification
Both intake and exhaust are showing: 13043 and 895.
1978 KZ1000 A2A
- PLUMMEN
02 Aug 2010 06:46 #387611
by PLUMMEN
i meant carb picture
