- Thank you received: 23
Starter clutch needle bearing
- seanbarney41
- '79 kz1000 LTD '75 Honda CB750
31 Jul 2010 13:57 #387270
by seanbarney41
Starter clutch needle bearing was created by seanbarney41
Anybody know where I can get a needle bearing that goes in the starter clutch for a '78/'79 Kz 1000. Couldn't find it at Z1 Enterprises. Possibly cuz I don't know exactly what it's called or have a part number.
- MFolks
- Thank you received: 540
31 Jul 2010 14:02 #387271
by MFolks
Replied by MFolks on topic Starter clutch needle bearing
www.kawasaki.com
or
www.bikebandit.com
should have the parts breakdowm numbers.
This might help for the sequence of repairs:
Over Running Starter Clutch Repair On the Older, Bigger 4’S
1. When preparing to repair the starter over running clutch have a few items on hand:
A. New alternator cover gasket.
B. New springs (3).
C. New spring caps (3).
D. New rollers (3).
2. If possible, put the motorcycle on the center stand and tilt to the right to reduce the oil volume in the alternator cover.
3. Place an oil catch pan under the left side of the engine to collect what small amount of oil that will escape when the alternator cover is removed.
4. Remove the foot shifter lever, left foot peg assembly and the sprocket cover.
5. Some Kawasaki’s have socket head cap screws(Allen type) and others may have fasteners with a Phillips type. If the latter is there, a # 3 bit seems to work the best for removal.
6. Remove the alternator cover and take care with the three wires coming from the alternator stator. These are the voltage supply wires for the motorcycle. Rest the cover on some newspaper or rags to prevent damage.
7. The magnetic Rotor or flywheel will probably require a removal bolt or puller. NOTE, SOME ENGINES HAVE LEFT HAND THREADS ON THE ROTOR!!
8. The over running clutch is bolted to the back of the rotor with three Allen head fasteners.
9. Separate the rotor from the over running clutch and inspect for damage in the springs, rollers, and spring caps. Replace any worn parts.
10. Re-assemble in reverse order taking care when re-installing the Alternator cover not to pinch any wires. If the cover will not re-install without force, check before any damage occurs.
B. New springs (3).
D. New rollers (3).
