- Thank you received: 23
alternator rotor pullin'? '79 KZ1000
- seanbarney41
- '79 kz1000 LTD '75 Honda CB750
31 Jul 2010 12:42 #387263
by seanbarney41
alternator rotor pullin'? '79 KZ1000 was created by seanbarney41
Well I know the trick of using a ball bearing and the fork cap bolt/axle for a puller but I don't have a ball bearing and it is inconvenient to pull those bolts right now. I devised a gear puller rig with a little 1/4" socket extension inserted into the bolt hole and a three armed gear puller hooked on the back of the starter clutch. Does anyone know if this will FSU?
- seanbarney41
31 Jul 2010 13:37 #387267
by seanbarney41
Replied by seanbarney41 on topic alternator rotor pullin'? '79 KZ1000
Well, never mind. I got bored/brave and tried it. This rig popped that sucker right off a there, no sweat.
- hocbj23
- Visitor
31 Jul 2010 17:33 #387306
by hocbj23
Replied by hocbj23 on topic alternator rotor pullin'? '79 KZ1000
if u could post a pic and brief discussion in the TECH write-up section,might help other riders with the same issue.Thanks.good job.bj
- seanbarney41
01 Aug 2010 15:47 #387497
by seanbarney41
I apologize for being totally ignorant of how to post a photo.
- Thank you received: 2098
01 Aug 2010 16:06 - 01 Aug 2010 16:09 #387502
by Patton
Replied by Patton on topic alternator rotor pullin'? '79 KZ1000
seanbarney41 wrote:
See following post also.
[Click on image to enlarge view.]
Last edit: 01 Aug 2010 16:09 by Patton.
01 Aug 2010 16:07 - 01 Aug 2010 16:09 #387503
by Patton
- seanbarney41
01 Aug 2010 16:13 - 01 Aug 2010 16:40 #387507
by seanbarney41
Did this work? Holy smokes, it did! What your seein' here... you'll probably notice that all the starter gears/parts have been removed by a previous owner, that's why I'm pullin the rotor-to replace all those parts. To do this, just remove the alternator rotor retaining bolt. Mine was a regular old right hand thread. My local bike shop had sold me a puller bolt with a left hand thread so it wouldn't work and I resorted to the pictured cave man tactics. Then I inserted a 1/4" socket extension into the bolt hole. There are probably any number of objects/small bolts/rods lyin' around your garage that will work just as well, just make sure it is long enough and thin enough to bottom against the end of the crankshaft and stick out for the threaded rod of the gear puller. I hooked the three arms of the gear puller on the back of the starter clutch. Ordinarily, I think you would have to hook the arms on the starter gear. Then just tighten up the puller. I think pullers with only 2 arms are more common and would work just as well. Mine popped right apart without excessive wrenching on the puller or bangin', cursing, wrench throwing. That guy in the upper left corner can be a mean mother- when frustrated. If he shows up in your garage be sure and keep him calm with beer.
Last edit: 01 Aug 2010 16:40 by seanbarney41.
- seanbarney41
01 Aug 2010 16:49 #387513
by seanbarney41
Man alive, thanks Patton. I thought I was on here to learn about KZ's, not how my damn com- poo- ta- works.
