ENGINE INFO PLEASE
- JARHEAD76
31 Jul 2010 07:35 #387209
by JARHEAD76
ENGINE INFO PLEASE was created by JARHEAD76
hI GUYS, i HAVE TWO BIKES AND Im curious about the engines. how do I know what engines I have. The one kz1100 is an 82 on the front forks it says engine motor KZT10A ser. no JKAKZBA11C. tHE KZ1100 SPECTRE says KZT10D SER NO. JKAKZBD1. Can I change parts on these two engines. I see the carbs on the spectre and the 82 KZ1100 look the same but tonite I see two hoses coming from the back of the carbs going to the ground ON THE SPECTRE the 82 red KZ doesnt have tbose. Thanks again
- otakar
31 Jul 2010 07:39 - 31 Jul 2010 07:41 #387211
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic ENGINE INFO PLEASE
What are you trying to change? Are you trying to cannibalize one bike to make the second run? Take pictures of both engines from the left side and post them. The engine #s are on the engine itself near the oil fill cap.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 31 Jul 2010 07:41 by otakar.
- JARHEAD76
31 Jul 2010 18:12 #387316
by JARHEAD76
Replied by JARHEAD76 on topic ENGINE INFO PLEASE
Thanks Gunny I will Do that. SEMPER FI
