- Thank you received: 3
Exhaust support bushing
- Lazyman06
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
- Lazyman06
- Thank you received: 2098
Is this the right bushing that goes into the rear passenger peg for the exhaust www.z1enterprises.com/detail.aspx?ID=4006
There are four of these rubber bushings, being two for each side of bike.
Look up the part on kawasaki.com (under frame fittings) and see the same part number 92092-010 as used in Z1E's listing.
That would be good enough for me.
...Look up the part on kawasaki.com (under frame fittings) and see the same part number 92092-010 as used in Z1E's listing....
For step-by-step instructions on how to find part diagrams on kawasaki.com
Click > kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
The full factory replacement part numbers are listed under the picture, which correspond with the abbreviated numbers shown in the diagram.
Diagram #34 in the parts list shows 92092-010.
(The list in kawasaki.com isn't shown in this post.)
Should find this parts diagram on kawasaki.com for 1979 KZ1000 MKII, under frame fittings.
[Click on image to enlarge view.]
When different bikes are shown in the signature, it's a good idea to identify which bike is being asked about.
In this case, it happens that the same 4 rubber bushings are also used on the police bike. (See following post.)
It's often convenient that Z1E also uses the factory part number in listings, where applicable.
- Lazyman06
