Kz650 top end torque specs
- 4rugrat1
- bountyhunter
- Thank you received: 337
- 4rugrat1
- bountyhunter
- Thank you received: 2829
- bountyhunter
Forgot to mention: my camshafts looked likethe bolts that hold the gears had threadlocker on them. The Kawi factory threadlock on mine is this banana yellow colored stuff and I seem to recall seeing it on those bolts(?) My manual doesn't cover it, but I would think some kind of non-permanent threadlock would be a good idea.Hi everybody, z1 messed up my order, and i couldnt get my clymer for the top end torque specs i need, if anybody knows the cam bolt torque specs and the cam gear specs they would be greatly appreciated. The model is a 1979 kz650c3.
- Old Man Rock
- Thank you received: 225
jarlef.no/Kawasaki/Series/Z/650/z650files.htm
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- PLUMMEN
- Thank you received: 104
z1 never messes up an order,and to prove it theyve got the kzrmhp out searching your neighbors outhouse for that missing clymers manualHi everybody, z1 messed up my order, and i couldnt get my clymer for the top end torque specs i need, if anybody knows the cam bolt torque specs and the cam gear specs they would be greatly appreciated. The model is a 1979 kz650c3.
