Two part question: Exhaust Flanges and Clutches
  • Kidkawie
  • Kidkawie's Avatar Topic Author
  • I bleed premix
29 Jul 2010 15:48
#386868
My Z1 is in need of some new exhaust flanges...rust. Is my only option OEM or aftermarket OEM or is there an alternative like a solid aluminum unit?
Also, after my Z sits a while the clutch seems to stick when I initially put it into gear. It basically lurches forward and stalls. After it "breaks free" it seems to work fine. Do the baskets/hubs in these bikes notch like an MX bike? The clutch lever feel is a bit stiff too.
Thanks.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Two part question: Exhaust Flanges and Clutches
29 Jul 2010 16:08
#386874
Shop around. I havn't seen radically different ones, but you never know.
The cluch plates should be removed, cleaned, then checked for thickness and warpage. If there is any warpage, it will be exagerated when hot, and cause the symptoms you speak of.
GL.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
29 Jul 2010 20:17
#386932
Kidkawie wrote:
My Z1 is in need of some new exhaust flanges...rust. Is my only option OEM or aftermarket OEM or is there an alternative like a solid aluminum unit?....
Z1E carries both styles of header clamps.
Good Fortune! :)
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
30 Jul 2010 04:26
#386972
If you get the newer style (alum) flanges from Z1E make sure you order the thicker exhaust gaskets.
I use the newer flanges and I have to double up on the gaskets.
Rob showed me the thicker gaskets while I was in Ohio. Roy
  • Kidkawie
  • I bleed premix
30 Jul 2010 05:33
#386974
Thanks.
I'll plan on taking the clutch apart. The baskets are pretty reliable though? I mean, they don't wear out fast?
1975 Z1 900
2004 KX125
