brazing pin holes in header?
  • Injected
  • Injected's Avatar Topic Author
29 Jul 2010 14:02
#386836
Has anybody here closed up some pin holes in a header head pipe with some braze? how did that work out?
The pin holes appeared after sandblasting the header... I can braze in my garage... mig is a trip to my buddy's shop, which is some miles and gas $$
Just wondered about the material difference, expansion, etc. and it might look different under the high heat paint.
Any ideas or feedback? THX.
1978 KZ650B2 modified project
  • Kawickrice
  • Kawickrice's Avatar
Re: brazing pin holes in header?
29 Jul 2010 14:09
#386839
I used JBweld on a set of smallblock chevy headders and it worked fine. As for a motorcycle where you can see most of the exhaust it will be a patch no matter what you do.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • jeffasaki
  • jeffasaki's Avatar
29 Jul 2010 14:19
#386843
Use the braze rod itll last forever if done right and you can blend it in with some sandpaper if it shows.Ive used braze rod on pipes about 12,786,234 times and never had a problem.
PS I HATE JB WELB = GARBAGE
Jeff
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • otakar
  • otakar's Avatar
29 Jul 2010 14:48
#386847
I actually filled in a one inch dent about 3/16 deep with braze. It worked out beautiful. If you want to fill a hole I would make sure that you open it up enough to remove any thin metal and than braze it closed.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Injected
29 Jul 2010 17:09
#386885
OK - sounds like braze it is...
THX
