noises...
- monstaru
- gotsta modificate
28 Jul 2010 18:51 #386680
by monstaru
to the end and back.....bitches
noises... was created by monstaru
s61.photobucket.com/albums/h56/monstaru/...nt%3DMVI_4553.mp4%26
wanna kinda get your thoughts.
i think it is a cam chain tensioner...?cheers, brian
- DFIGPZ
- Thank you received: 122
28 Jul 2010 21:14 #386709
by DFIGPZ
1984 750 Turbo
Replied by DFIGPZ on topic noises...
Brian
tough to hear cam chain yes it could be. and if my memory serves me correct i think the 550 kaw had a primary chain much like the kz650 / 750 engines. these make noise and if carbs are out of sync they would rattle at idle.
1984 750 Turbo
- monstaru
- gotsta modificate
30 Jul 2010 07:09 #386988
by monstaru
Replied by monstaru on topic noises...
well, thay are out of sync a bit.have not tackled that demon as of yet.
- apbling
30 Jul 2010 07:14 #386989
by apbling
Replied by apbling on topic noises...
is it just me, or does it sound like he may have a slight miss?
- TeK9iNe
- What did you do!?!
- Thank you received: 28
30 Jul 2010 09:24 #386999
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic noises...
I think the slight miss your hearing was something to do with the camera, though I could be wrong.
With the primary chain on those old machines, even when in perfect sync they can rattle some at low rpms due to stretch and push/pull motion of pistons/camchain.
Be sure to tune your idle mixture screws. Dynamic vacuum sync carbs, and run the idle up a bit from stock, at say 1200rpm or so.
Should be good to go...
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- monstaru
- gotsta modificate
30 Jul 2010 10:25 #387013
by monstaru
i don't have a sync tool yet.can't really afford it right now.got a 40 dollar quote from the local roundy's kawasaki shop.they should sync them up right.
:B
cheers, brian
:B
cheers, brian
- Capt America
- Born Bad
30 Jul 2010 13:09 #387045
by Capt America
Capt A merica
1983 K1 750 twin
Ontario, Canada.
Replied by Capt America on topic noises...
TeK9iNe hit the nail on the head imo.. very distinctive sound that one.. old 650 Honda's were famous for it.
Capt A merica
1983 K1 750 twin
Ontario, Canada.
- apbling
30 Jul 2010 13:38 - 30 Jul 2010 13:40 #387050
by apbling
Yeah, my 750 primary chain rattles too. At 1200 rpm it really quiets down.
I thought there just seemed like a miss at idle and then once he reved the bike, it seemed to smooth out a bit. Then again, if he hasn't synched them yet, that will help.
Last edit: 30 Jul 2010 13:40 by apbling.
- Thank you received: 2098
30 Jul 2010 14:20 #387056
by Patton
Replied by Patton on topic noises...
Equally performing cylinders are critical to smooth engine pulses, which is a primary objective of carb sync together with fine tuning of pilot circuit (the final step after perfection of ignition and compression components and other carb and fuel supply matters).
It's possible to achieve relatively quiet steady running at even lower than recommended idle rpm, but which could be dangerous due to inadequate oil pressure.
