tach drive leaking
- rodneyo
tach drive leaking
11 Apr 2006 11:28
I have a 8o ltd1000,and my tach drive is leaking.Is there another seal besides the oring on the outside?because Ive replaced it and it still leaks.Not to mention blowing oil all over the front of my motor.I tried to look at a diagram on kawasaki.com.But I guess it doesnt go back that far.Does anyone have a diagram?Any help would be appreciated.
- wireman
- MDawnz1
Re: tach drive leaking
11 Apr 2006 11:51
Check Bikebandit.com and see if they have the fiche up (online) for your bike.
1974 Z1a, still 903
- MDawnz1
11 Apr 2006 11:51
1974 Z1a, still 903
- BARNEYHYPHEN
11 Apr 2006 12:02
Not totally sur you have the same tach drive as is on the 73/78 900/1000's but if you do, there is a small oil seal inside the tach drive casing through which the spindle passes.
- cudaosix
11 Apr 2006 15:12
The fun part is getting the tach drive out of there isnt it? Theres the tach drive seal, an o-ring and washer for the cable. Shouldnt be leaking after that. If thats what you replaced and still have oil down the front of your engine then clean the area off well so you can locate where its coming from
www.redlinecycle.com/Tach%20Seals.html
Post edited by: cudaosix, at: 2006/04/11 18:12
- koolaid_kid
12 Apr 2006 15:26
On BikeBandit, I believe you want parts 12, 14 & 15.
I bought a kit with all 3 parts on eBay for my KZ750E, it worked like a charm.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
