Starter Clutch
- BIGD
27 Jul 2010 10:38 #386246
by BIGD
Had 1981 KZ1000 M1 From 1981-1995 Canadian Model
Have 1981 KZ1000 M1 US Model
Starter Clutch was created by BIGD
Could you please explain to me what the spring, pin and rollers do in the starter clutch. And when they are worn out and need replacing, how do they affect my starter. When I attempt to start the bike, the starter just spins and does not engage. New parts are ordered from Z1. Thanks Don
- bountyhunter
- Thank you received: 337
27 Jul 2010 11:09 - 27 Jul 2010 11:15 #386252
by bountyhunter
Replied by bountyhunter on topic Starter Clutch
The rollers cause friction against the starter clutch hub when the starter spins with respect to the crankshaft. When the engine fires, the crankshaft starts "leading" the clutch (spinning ahead with respect to the clutch) which releases the clamp on the clutch hub. The springs allow the rollers to spin outward (due to centrifugal force or radial acceleration) as the shaft RPM increases so the rollers don't touch the clutch hub while the engine is running.
If the starter just spins, it sounds like one or more rollers can't properly engage the hub maybe because it isn't free to move in and out.
Last edit: 27 Jul 2010 11:15 by bountyhunter.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
27 Jul 2010 12:14 #386278
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Starter Clutch
Alot of times the starter clutch - to - stator magnet bolts can come loose and wreak havoc in there.
Make sure they are all torqued down good (spec = 30 ft.lbs), with some red thread locker.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
