Pod air filters?
  • Omaha Rider
  • Omaha Rider's Avatar Topic Author
Pod air filters?
26 Jul 2010 21:37
#386136
Anyone know if these are any good? They are pretty cheap and aren't K&n, so idk.
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...&itemid=360281330128
1978 KZ650 SR D
  • seanbarney41
  • seanbarney41's Avatar
  • '79 kz1000 LTD '75 Honda CB750
Re: Pod air filters?
26 Jul 2010 22:24
#386141
Those look like Emgo, although it doesn't list any brand names. I used similar ones on a cb 360. They were good quality and definately flowed more air than the stock airbox without a filter...but not as much as a K&N. You know a filter is flowing more air when your mixture goes lean! Also K&N's are indefinately cleanable and guaranteed. Emgo's cost $37 for 4- k&n's about $100- Emgo's win! Buy a set of K&N's off some cb 750 guy at the swap meet cuz he can't get 'em to work on those shitty keihins.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
26 Jul 2010 22:57
#386144
The no-name pods are OK, but just be sure not to let them dry out or get wet, as some of them are made from paper medium, and I've seen rotting pieces get sucked into engines.
They are very easily affected by side draft and other phenomenon that makes for lean conditions.
Jet with care.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • JMKZHI
  • JMKZHI's Avatar
26 Jul 2010 23:29 - 26 Jul 2010 23:29
#386154
seanbarney41 wrote:
.... Also K&N's are indefinately cleanable and guaranteed. Emgo's cost $37 for 4- k&n's about $100- Emgo's win! ....
Uh, explain please. I don't believe the Emgo filters will last as long as the K&Ns - not even sure if the cheapies can be cleaned & reused. It doesn't really matter to me, though, since I prefer the stock airbox.
Last edit: 26 Jul 2010 23:29 by JMKZHI.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
27 Jul 2010 03:54
#386174
Buy the from z1enterprises if you decice to go this route.
He sponcers the site.
I use this type filter and replace them yearly.
What bike are you going to use them on?
  • 9am53
  • 9am53's Avatar
  • homebrew, and some bbq
27 Jul 2010 04:30
#386176
I have these and they are just like k&n, same cloth material and good quality, but much cheaper. And APE advertises here too.
www.kzzone.com/carbs.html
and since they are ovals people actually think they are K&N
  • Polar_Bus
  • Polar_Bus's Avatar
27 Jul 2010 09:14
#386222
If your bike still has the stock airbox do yourself a HUGE favor and leave the airbox on. I can't tell you how many horror stories I've read on the internet about $hitty running bikes after a pods install.. unless you have a dyno in your garage and about 20 hours of tuning time available pass on pods !
Bikes:
'84 GPz1100
'06 HD Fatboy
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
27 Jul 2010 09:24
#386229
I have a set of K&N's on my Z1, they're about 30 years old. Ya think I should update them or they good to go? Says "oil type" on the end cap.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • Polar_Bus
27 Jul 2010 10:37
#386245
Nah. The 30 years of caked on dirt is what's keeping the mice out of your carbs... :laugh:
Bikes:
'84 GPz1100
'06 HD Fatboy
  • seanbarney41
27 Jul 2010 13:35
#386293
I've found if you got CV type carbs the swap to pods is not as drastic and is a definite performance improvement. Slide type carbs? Get ready for big time spark plug choppin' and carb pullin', jet changin', needle clip movin' mayhem. Is it worth the trouble? I don't know yet. Still involved in all that mayhem and I ain't even got it to run clean yet.
  • ace
  • ace's Avatar
  • 78kz1000
27 Jul 2010 14:39
#386331
ive got the emgos and notice the rubber splittin where they mount. id go k&N NEXT TIME
78kz1000
  • muddy1
  • muddy1's Avatar
  • 1980 Kz1000 LTD B4
27 Jul 2010 15:12
#386341
get these instead, scroll down to see the filters
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
