valve lash, need help! 79 kz650 c3.
- 4rugrat1
26 Jul 2010 21:11 #386127
by 4rugrat1
valve lash, need help! 79 kz650 c3. was created by 4rugrat1
i just took the valve lash from my 1979 kz650 c3, its
cyllinder #
1-exhaust.0045
intake.007
2-exhaust.0025
intake.003
3-exhaust.004
intake.004
4-exhaust.003
intake.004
is this a normal reading? or should i do some shimming to them? it seems like my bike has gone sluggish and has a stumble between 5-6k rpm. any help is greatly appreciated!!
cyllinder #
1-exhaust.0045
intake.007
2-exhaust.0025
intake.003
3-exhaust.004
intake.004
4-exhaust.003
intake.004
- 4rugrat1
26 Jul 2010 21:15 #386129
by 4rugrat1
Replied by 4rugrat1 on topic valve lash, need help! 79 kz650 c3.
cyllinder 1&4 are running significantly leaner than 2&3, any help about this would be appreciated also!
- TeK9iNe
- What did you do!?!
- Thank you received: 28
26 Jul 2010 23:07 #386147
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic valve lash, need help! 79 kz650 c3.
With those gaps, I would say your problem is not valve lash, and more like carb cleaning/tuning/etc.
You might want to try swapping the #1 intake shim with the #2 exhaust shim to see if they come closer to spec.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- 4rugrat1
27 Jul 2010 00:28 - 27 Jul 2010 00:59 #386165
by 4rugrat1
my carbs are cleaned i cleaned them good a first time, then doubted my work and went at it again making sure that i had everything SPOTLESS. i have an dyna s and green coils, timing is dead on. but cylinder 1&4 run leaner still. i was looking at my cam chain, and the arrows on the 26th pin apart from eachother, but at tdc, the two arrows do not line up, could this be causing a problem like that? or should i not worry about it? should i move the cam one tooth so that the arrows line up? i also forgot to mention that my compression is vary good, and is not off from eachother much at all.
Last edit: 27 Jul 2010 00:59 by 4rugrat1.
