question on piston rods
- kz750ohio
26 Jul 2010 16:18 #386018
by kz750ohio
1982 kawasaki kz750 with mikuni carbs bs34, stock everything else.
question on piston rods was created by kz750ohio
I am putting my baby together. I had to get another crank because the original was below spec. The question I have, does the piston rods need to go in a certain order. The only thing I have found in the book is to match the rod markings. For example, make sure rods 1 & 2 have the same markings and 3 & 4 have the same markings so the weights will be the same.
Thanks,
Max
Thanks,
Max
- BSKZ650
- Thank you received: 14
27 Jul 2010 05:53 #386190
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic question on piston rods
order wise, it really dosent matter, but you need to keep the caps on the rods they came from, the rods are honed to exact size and if you mix them the result is not goingto be pretty.
