- Thank you received: 3
stuck in neutral..
- murr50
25 Jul 2010 11:34 #385562
by murr50
1977 kz650 C
stuck in neutral.. was created by murr50
so i was out for a ride today and all of a sudden my bike went out of gear, like the clutch was in. I pulled over and shifted into first, but no movement. The bike just doesnt seem to want to go into gear. Anyways i called a friend to pick my bike up in his truck, and when i got home and moved it into the garage i noticed a clicking noise sort of like a mountain bike makes when you arent pedalling. any thoughts?
ps the bike is a 77kz650
1977 kz650 C
- taildragger1197
- Thank you received: 17
25 Jul 2010 11:50 #385566
by taildragger1197
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
Replied by taildragger1197 on topic stuck in neutral..
Sounds like you spun the nut off the front sprocket. If so, make sure you bend the lock tab down after you tighten it.
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
- murr50
25 Jul 2010 12:16 #385574
by murr50
1977 kz650 C
Replied by murr50 on topic stuck in neutral..
well i just checked the sprocket and sure enough the nut was gone. Thanks very much for the help. now for my next question, what size of nut is that? i check z1enterprises and they do not have any.
1977 kz650 C
- KZ900A4
25 Jul 2010 21:20 #385788
by KZ900A4
76 KZ900A4
Replied by KZ900A4 on topic stuck in neutral..
According to Kawasaki. For a KZ650-B1 (1977), it's a 20MM nut. Part number 92016-028.
76 KZ900A4
- murr50
26 Jul 2010 16:46 #386029
by murr50
1977 kz650 C
perfect i got the nut. last question... is there a specific tourque setting that is used here or should i just tighten the thing as much as possible?
1977 kz650 C
- TeK9iNe
- What did you do!?!
- Thank you received: 28
26 Jul 2010 23:26 #386153
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic stuck in neutral..
I believe its 60 ft-lbs, but someone else might have the actual spec.
Just be sure to use some blue thread locker, and it will not likely come off again until you ask it to.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
