- Thank you received: 19
How durable is a KZ motor?
- larrycavan
- Visitor
25 Jul 2010 11:24 - 26 Jul 2010 06:07 #385555
by larrycavan
How durable is a KZ motor? was created by larrycavan
Here's a recent actual accounting of how durable they are.
1327 big block that was all kinds of screwed up running 6.28 1/8th mile.
The combo:
1327 Big Block with street compression J pistons
Andrews 8X cams
86-88CFM @10" head with stock valves - shaved down so far they cut into the intake valve seats.
38mm Trons [not even close to dialed in]
What was wrong with the motor?
2 overlapped oil wave rings
All 4 intake valves where hitting the pistons because the intake cam was 2 way over advanced. The motor had over 300lbs static compression
Block was not machined properly for the cam chain shoe. That caused the front idler to be dragging and not spinning free.
The piston valve relief cut outs looked and measured up to show they were never machined properly from the manufacturer. They measured 35.5mm at the widest section on the intake relief pockets.
The cam new cam chain was so beat after about 10 passes that you could hold it and 5 or 6 links would stand straight out!
In short this thing was an absolute abortion.
It's all been fixed now and if it doesn't rain next Friday we'll find out how it runs now..
Bottom line is this. Aftermarket block was not machined right and neither were the pistons. Inexperienced guy assembled the motor and didn't notice any of those problems.
I'm not naming names on the parts. 'nuff has already been stated that you should know if it's aftermarket...you need to look it over really well before you call it good.
I'll say this much IT WAS NOT APE COMPONENTS
Larry C
The combo:
Andrews 8X cams
Larry C
Last edit: 26 Jul 2010 06:07 by larrycavan.
- porchev914
25 Jul 2010 11:35 #385563
by porchev914
FRANKEN Z!
Replied by porchev914 on topic How durable is a KZ motor?
Soooo, pretty durable then? :laugh:
FRANKEN Z!
- hocbj23
- Visitor
25 Jul 2010 12:05 #385571
by hocbj23
Replied by hocbj23 on topic How durable is a KZ motor?
and it was running 6 sec. 1/8ths? Damn,there is hope for me yet.Lol.bj
