- Thank you received: 5
3000 miles without a camshaft tensioner !
- ELCouz
Today when reinstalling the valve cover on my GPZ 750 '82, i needed to reset the camshaft tensioner at TDC like people told me. I have the cross wedge automatic tensioner. When i have unscrewed the big bolt ... sh!t no spring and no push rod came out! I don't know what PO did but hell I've ridden 3000 miles without a functional tensioner.
So i've put a spring and push rod from my KZ550 '83 and it run like crap and i could hear a big chain rattle then the engine died. Removed the spring and push rod ... ran great ... wtf is going on ? Maybe thats why PO removed it but still i can't understand why its like that.
Is that dangerous?
Thank you,
laurent
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
- ELCouz
Here's a picture of the FSM
Push Rod Stop and Spring are missing (#7 & #
Can i continue to run like this?
regards,
laurent
- WABBMW
- Let The Good Times Roll !
- Thank you received: 16
I cannot explain why the chain noise with the tensioner and quiet without the tensioner. Seems that it would be just the opposite.
I have all the internal parts off a tensioner that was on my '82 KZ650. You can have them if you want. Somebody (names will not be provided), got over-energized when tightening the screw-on cap that holds the spring and twisted it off.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
- ELCouz
The APE manual tensioner scares me.... i don't know when the chain is slack or too tight... i'm not to good at guessing for that and I've not earned my KZ doctor status yet :lol:
some are able to tell just by hearing how the cam chain move if it's too tight or slack...
EDIT:
I would like to but i'm not even sure it's compatible. My kz550 have the same type of tensioner but different shape...and the cap bolt is longer.
I guess everyone change for manual tensioner but i'm unsure ... to forget to readjust the tension could be a costly mistake with the manual tensioner !
Thanks for your support WABBMW!
regards,
laurent
- guitargeek
- Thank you received: 50
The front guides are known to wear through where the block meets the case. If they're not replaced, the cam chain may eventually saw it's way through the case. You can remove that guide without pulling the head, and you can inspect the rear guide to make sure it moves okay. When you're sure all that's good, retime your cams make sure your cross-wedge tensioner is deburred and greased and works like it's supposed to... or just put a manual tensioner on there.
You change your own oil periodically, right?
You clean, lube, and adjust your drive chain?
It's just one more maintenance item. The weird thing about it is that you do it by feel.
It's only intimidating until you do it the first time, then you're like, "Oh, okay, that's what they were talking about."
Yes, kinda like sex.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- ELCouz
Pull your cams and take a look at your guides. When I pulled my engine apart, I found this:
How many miles your bike had when you pulled it?
This is not normal unless you had a lot of miles.
Even my KZ550 with nearly 30 000 miles don't have that much wear on the guides.
i've checked quickly the tentioner guide with a flashlight yesterday when i checked the valve clearance... looked good anyway...
i will remove the tention assembly and inspect it.
You can remove that guide without pulling the head, and you can inspect the rear guide to make sure it moves okay. When you're sure all that's good, retime your cams...
This ain't easy for me this is my daily commuter and sometime you touch something and you end up with more problems. At least, winter is my break for that kind of thing.
regards,
laurent
- ELCouz
thank you,
laurent
- loudhvx
- Thank you received: 1616
The damage Guitargeek posted shows the type of damage that can happen if the valve cover is pressed down into place while the chain is tensioned.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- guitargeek
- ELCouz
The pushrod is held with the (self-made) screw on its side so when the travel limit screw is tighten it will lock the pushrod in place and cannot move wow!
Also, maybe he did this because he broke half the tensioner .The main bolt where it use to have the push rod stop has been over-torqued and most of it got snapped.
I guess to cheap to buy APE.
I will try to readjust the PO made chain tensioner and when i will receive the original complete tensioner i will switch them.
jeez what else he did to the engine... so wonderful..too many surprises are waiting to be discovered ! Can't wait!!!! :dry:
regards,
laurent
