- Thank you received: 5
Shim decision thick or thin.
- dshelly
23 Jul 2010 08:22 #384900
by dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Shim decision thick or thin. was created by dshelly
Hi all,
I am currently checking my valve clearances on my '78 kz1000A2 and found #1 intake a little tight. Can't get a .002 feeler gauge in it. However I can spin the bucket. The shim in it is a 2.25 but I don't have a 2.2 to replace it with. I do have A 2.15 I really want to get it going so I can ride this weekend. So Is 2.15 too thin or should I put the 2.25 back in untill I get a 2.2?
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- RonKZ650
- Thank you received: 240
23 Jul 2010 09:35 #384908
by RonKZ650
Replied by RonKZ650 on topic Shim decision thick or thin.
2.15 should be perfect.
- dshelly
23 Jul 2010 09:44 #384912
by dshelly
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Replied by dshelly on topic Shim decision thick or thin.
That's what I Put in. Now it takes a .005 feeler gauge and runs fine. I usually like from .003 to .004 but .001 won't hurt anything.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- Jeff.Saunders
23 Jul 2010 11:04 #384948
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic Shim decision thick or thin.
Originally Kawasaki recommended 2-4 thou clearance on these bikes, but adjusted this to 2-6 thou in later maintenance releases.
On my bikes I prefer to go slightly wide rather than tight - and will NEVER leave clearance under 3 thou. I try to get around 3.5 to 4.5 thou clearance where possible.
Z1 Ent on Facebook,
