blasting/painting Z400
- Brown Bear
23 Jul 2010 04:15 #384839
by Brown Bear
blasting/painting Z400 was created by Brown Bear
i am snadblast my KZ400 engine as it looks it such bad shape, what is teh best way to go about respraing it? other than high temp paints, i dont want to use a brush at all. and would i need to be primed aswell?
oh where can a get a full gasket set from also not too expensive? iv been told other models will fit myne as it is the 4 cyl
- 9am53
- homebrew, and some bbq
- Thank you received: 3
23 Jul 2010 04:39 #384845
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
Replied by 9am53 on topic blasting/painting Z400
I'd be careful blasting with actual sand, it is likely to mar the aluminum. I have had good luck blasting with baking soda, it cleans really well. Regarding the gasket set I always get almost everything from
www.Z1enterprises.com
'84 GPz900r
'71 CB350
- Thank you received: 2829
23 Jul 2010 07:38 #384883
by 650ed
Replied by 650ed on topic blasting/painting Z400
Brown Bear wrote:
PLEASE post a picture!! I have never seen or even heard of a 4 cylinder KZ400. Ed
am snadblast my KZ400 engine..... iv been told other models will fit myne as it is the 4 cyl
- OnkelB
- Thank you received: 80
23 Jul 2010 12:05 - 23 Jul 2010 12:05 #384972
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic blasting/painting Z400
Last edit: 23 Jul 2010 12:05 by OnkelB.
- OnkelB
23 Jul 2010 12:06 - 23 Jul 2010 12:06 #384973
by OnkelB
Last edit: 23 Jul 2010 12:06 by OnkelB.
23 Jul 2010 20:23 #385131
by 650ed
Thanks! I don't know how I missed ever seeing one considering I've been riding bikes since 1965. Maybe I saw them back then and my memory has gotten dull, or maybe I saw them back then and my memory has gotten dull, or maybe I saw.............
- loudhvx
- Thank you received: 1616
23 Jul 2010 20:51 #385160
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic blasting/painting Z400
It is basically the same bike as the KZ500/KZ550 series. The motor just has a smaller displacement, but the castings are virtually the same. The actual bike is the same size as the KZ550's.
They are rare and cool, but are slower than a run-of-the-mill 550, so not very desirable since you can make a 550 look just like them with some paint and badges.
There are a few minor detail differences:
Cam timing, transmission gearing, carbs are almost identical but are 1mm smaller diameter, small differences in brake disk diameters.
1981 KZ550 D1 gpz.
Other links.
- Brown Bear
25 Jul 2010 09:23 #385530
by Brown Bear
Replied by Brown Bear on topic blasting/painting Z400
using playsand from B&Q. lol. its working totaly fine. have had to soakd the parks in an engine degreaser etc. they was bad...... but hope in time i will get there. if i cant get all the paint off the im not overly bothered really. i will be respraying them anyway. lol. just want it to look good..
