Simple Green + power wash = good engine cleaner?
  • kz.chris
  • kz.chris's Avatar Topic Author
22 Jul 2010 13:17
#384625
Would it be ok to clean the entire bike like that?
Soak the bike in Simple Green and then pressure wash the piss out of it?
thanks
1977 Kawasaki KZ650
Re: Simple Green + power wash = good engine cleaner?
22 Jul 2010 13:34
#384628
Keep in mind that there are a variety of rubber seals, etc. on a bike that seal components containing grease and oil. If you hit a rubber seal (or possibly even a gasket)with a pressure washer you may force water into a bad place. Ed
  • dblhdr
  • dblhdr's Avatar
22 Jul 2010 14:28
#384637
I use my power washer on my bike all the time. :unsure: Just remember that you have to cover up anything you don't want to get wet. I use baggies to cover up areas I want to keep dry. I also don't use the wand up close to the bike because of the issues discussed above. Remember to lube your chain when you're done. I use an electric home power washer that's not all too powerful but more than enough to get the job done. Heck it isn't much diferent than riding in the pouring rain for a few hours like I had to on my last road trip.:blink: You should also remember that anything you spray on areas that will get hot might etch if you leave a residiue. :ohmy: I also use a compressor to blow the excess water off after I'm done spraying.:dry:
1981 KZ1000 Police Special coverted for civilian use with passenger seat, custom luggage rack, and paint. Daily rider.
2006 Harley Davidson Road King FLHR1
  • kz.chris
22 Jul 2010 15:34
#384652
Thanks for the tips
1977 Kawasaki KZ650
  • MFolks
  • MFolks's Avatar
22 Jul 2010 18:34
#384711
Avoid getting any cleaning compounds into electrical connectors as on most Japanese motorcycles they are not sealed.
The soap will corrode the male and female pins, making troubleshooting a real PITA!
  • Polar_Bus
  • Polar_Bus's Avatar
24 Jul 2010 06:05
#385216
Simple Green is good, but this stuff is awesome :
www.clean-rite.com/
PP has some SERIOUS concentration, so spray it on, let it sit for a few min. then THOUROUGHLY wash it off !
Bikes:
'84 GPz1100
'06 HD Fatboy
  • larrycavan
  • larrycavan's Avatar
24 Jul 2010 06:15 - 24 Jul 2010 06:16
#385217
Actually high pressure washing isn't a good idea on motorycles unless it actually needs it.
A good cleaning agent with a garden hose is the better choice when you clean your bike regularly.
Park it in the shade, mist it with simple green and an immediate mist of water. Let it soak for about a minute [do not let the simple green dry on the bike].
Rinse, then bucket wash with car wash soap.
NEVER PUT SIMPLE GREEN ON A HOT ENGINE.
High pressure water gets forced past your wheel bearing seals and starts the corrosion process inside.
I always take the WD40 with a nozzle and spray the wheel seal area after I wash the bike.
WD on an old rag is excellent for cleaning the drive chain as well.
Works for me anyway :)
Last edit: 24 Jul 2010 06:16 by larrycavan.
  • larrycavan
24 Jul 2010 06:19
#385218
www.clean-rite.com/
Purple Power is awesome stuff but you have to be very careful with it on Aluminum. Leave it on too long and it can turn it dark.
I use PP & Water in my parts washer in a 40/60 ratio. PP will eat the carbon our of combustion chambers. Again though, you have to be careful how long you leave stuff in it.
Worst part is not all aluminum behaves the same. Some can be left in the parts washer overnight and some will turn start to turn black after only an hour or so.
Larry C
  • Kawickrice
  • Kawickrice's Avatar
24 Jul 2010 08:27
#385240
I could be wrong but simple green is corrosive to aluminum and will take any and all shine away. I sprayed my whole engine one time and it removed the grease but screwed up my finish on the aluminum. Do a test spot to be sure. Gunk with a toothbrush and a garden hose will work just the same without damage to the finishes.
My .02 cents
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Polar_Bus
12 Aug 2010 07:13
#390318
larrycavan wrote:
www.clean-rite.com/
Larry C
I actually had a situation on my '87 GSXR's engine where PP actually left behind an odd whitish residue. It wouldn't wash off. I ended up spraying the engine down with WD40, and gave it a good wipedown, and engine looked good as new. I further recommend you "thin" out PP to a 50/50 dillution before spraying it on painted engine cases.
Bikes:
'84 GPz1100
'06 HD Fatboy
  • otakar
  • otakar's Avatar
12 Aug 2010 07:22 - 12 Aug 2010 07:24
#390320
I do it all the time but I use ZEP Citrus Degreaser. Which i buy at home depot. It leaves no residue. any place that sells Simple green should sell the ZEP. It is about $10/Gal. But I found out you don't even have to use a pressure washer, just a garden hose will do just fine.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 12 Aug 2010 07:24 by otakar.
  • Polar_Bus
13 Aug 2010 06:13
#390573
And you get a wonderfull aroma of fresh squeezed oranges while you wash ! :laugh:
Bikes:
'84 GPz1100
'06 HD Fatboy
