83 KZ1100 LTD Puffing a little smoke?
- robert1083
22 Jul 2010 10:27 - 22 Jul 2010 10:34 #384601
by robert1083
83 KZ1100 LTD Puffing a little smoke? was created by robert1083
I was thinking about buying an 83 kz1100 ltd shaft drive, with 28,700 miles. It is on sale for $1650, it seems to be in good condition, except the seller says that it is starting to puff a little smoke from the right pipe. I was wondering what that could be and how much it would cost to repair? Should I ask for a lower price? I'm currently on an 83 kz750 chain drive. Thanks for any input! Btw, would there be a huge difference in power and weight between the 2 bikes?
Last edit: 22 Jul 2010 10:34 by robert1083.
- MFolks
- Thank you received: 540
22 Jul 2010 10:34 #384602
by MFolks
Replied by MFolks on topic 83 KZ1100 LTD Puffing a little smoke?
Smoke could be valve stem seals or piston rings. Does the owner list the compression for the cylinders?
Hopefully the valve clearances have been checked lately or there is a good chance of burning valves/valve seats.
- Thank you received: 2098
22 Jul 2010 10:40 #384603
by Patton
Replied by Patton on topic 83 KZ1100 LTD Puffing a little smoke?
robert1083 wrote:
With only 28,700 miles, the smoke may result from worn valve stem seals (especially when engine is first started and for a mile or so until things warm up). Not a big deal.
Oil burning from poor compression due to piston/ring/cylinder wear would continue smoking on and on.
With smoke only from one pipe, I would guess poor valve stem seal. A compression test would be more enlightening.
- bountyhunter
- Thank you received: 337
22 Jul 2010 10:44 #384604
by bountyhunter
Replied by bountyhunter on topic 83 KZ1100 LTD Puffing a little smoke?
If it was rings, you would see more smoke when you get hard on the throttle, and it will do it even after warmed up. Valve stem seals usually more smoke at startup then goes away as it runs a while. Would definitely do a compression check.
