1984 GPz 750 turbo cam question
- 2006hhr
21 Jul 2010 17:21 #384448
by 2006hhr
1984 GPz 750 turbo cam question was created by 2006hhr
There is a set of these on ebay right now, just wondering what the specs are and if they are a good match fro my 650 motor. What concerns me the most is the fact that they have the tach drive gear, which i thought was deleted when they went to electronic tach. Link is here
cgi.ebay.com/ebaymotors/Kawasaki-84-GPZ7...&hash=item45ee58a89e
- PLUMMEN
- Thank you received: 104
21 Jul 2010 18:19 #384468
by PLUMMEN
Replied by PLUMMEN on topic 1984 GPz 750 turbo cam question
turbo cams are usually on the small side since the motor is force fed
- T_Dub
- Thank you received: 25
21 Jul 2010 18:28 #384469
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic 1984 GPz 750 turbo cam question
GPz 750 turbo cams are exactly the same as 650 cams, don't do it. Buy regular GPZ750 cams if you can.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- 2006hhr
21 Jul 2010 18:37 #384472
by 2006hhr
Replied by 2006hhr on topic 1984 GPz 750 turbo cam question
Thanks, have a set of KZ750 cams from 1982 or 1983 to install, still looking for a set of GPz cams tho...
- steell
22 Jul 2010 20:06 #384767
by steell
Replied by steell on topic 1984 GPz 750 turbo cam question
T_Dub wrote:
Absolutely correct, 750 Turbo cams don't usually have the tach drive gear cut though.
Personally, I wouldn't run 83-85 GPz750 cams in a 650, they give up mid and low range on the 750's to get more power on top. And that would make a 650 a pain on the street.
I would use the KZ750 cams though.
- DoubleDub
- Visitor
22 Jul 2010 21:08 #384801
by DoubleDub
Replied by DoubleDub on topic 1984 GPz 750 turbo cam question
Steell - what's the comparable difference between 650 and 750 Kz cams?
- steell
22 Jul 2010 21:32 #384806
by steell
DoubleDub wrote:
The specs are posted here somewhere, and I believe on www.750turbo.com also. I don't have them readily to hand though.
KZ750 cams have more lift and duration than 650 cams, but less than 83-85 GPz750 cams.
- DoubleDub
- Visitor
22 Jul 2010 21:33 #384807
by DoubleDub
Thanks!
