Transmission gears....should I be able.
  • Hynominys Bosh
  • Hynominys Bosh's Avatar Topic Author
10 Apr 2006 16:01
#38372
Should I be able to feel the notches in the shifter (like on a car) when I manually turn the knob? Cycle off of course. KZ1000P.
Right not I have 2 notches. Neutral (cause the sprocket spins) and in gear, thats it.
I dont know the mechanics of a motorcycle to know if this is correct. To me it doesnt seem right. If this is in fact broke, how do I go about fixing...what is the cause.
Thanks
  • fixer5000
  • fixer5000's Avatar
Re: Transmission gears....should I be able.
10 Apr 2006 16:08
#38375
sounds normal to me....you have to be moving in order to upshift and downshift these things.....steve
1978 kz650b pretty much stock
massachusetts
  • Hynominys Bosh
10 Apr 2006 16:13
#38376
sweet, thanks. I got this thing but never rode it before I tore it down for a rebuild, wanted to make sure before I set sail :)
  • wireman
  • wireman's Avatar
10 Apr 2006 16:15
#38379
bike will not shift to second gear unless output shaft is spinning.neutral and first is all you should get if bike is not moving.;)
  • hwms
  • hwms's Avatar
10 Apr 2006 17:27
#38410
Would the careful perusal of a manual be advisable before "weighing anchor"??
