- Thank you received: 5
Advice on compression readings...
- ELCouz
...measuring while the piston are at their deepest position ?
Anyway if it's not possible you can be sure i change the base gasket + hone + new rings. It's just because it will cost a little more
and well if go to this level i could get it bored and fit oversized rings.
laurent
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
- steell
Didn't you add oil and the compression came up?
That means it isnt the valves...
I typed a long explanation with examples demonstrating that your statement is incorrect, but then it hit me.
Is there anything at all that would change your mind?
- Motor Head
- Thank you received: 391
- ELCouz
A "Leak Down Test was mentioned, that is what you need to do if you want to know what is leaking
Yes i know but Leak down test is the opposite of compression test. You induce pressure in the cylinders and you look for how much pressure you loose. But how it can tell you where it leaks? You will just know that you loose pressure (which i already know because of the low compression 121 psi).
I am right ?
thank you guys,
laurent
- dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- ELCouz
If its leaking you'll know it. You can hear it hiss. Or if its a head gasket ,take a spray bottle of soapy water and spray the area of the gasket any leaks will bubble.
As a cheap version of a leak down tester i could use my compression tester adapter and inject 100 psi of compressed air into the cylinder and look for hiss and bubbles. Sure i wouldn't how much pressure I'm loosing but I've already know there's a problem with that cylinder.
EDIT: i think you can't know for the rings and side blown head gasket (not cylinder to cylinder)... like leaking internally where the cam chain is.
regards,
laurent
- ELCouz
Thank you very much for everyone that participated in this thread ....
regards,
laurent
