83-84 GPZ 1100 cams
- Buda
83-84 GPZ 1100 cams
17 Jul 2010 10:53 - 21 Jul 2010 17:06
How do I tell the intake from the exhaust cam?
One has r1 stamped on and the other has r6. Does it even mater?
Thanks
Thanks
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
10.25 to 1 comp
K&N pods
GPZ cams
Last edit: 21 Jul 2010 17:06 by Buda.
- Buda
Re: GPZ cams
17 Jul 2010 11:30
Anybody..come on guys...help me:)
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
10.25 to 1 comp
K&N pods
GPZ cams
- otakar
Re: GPZ cams
17 Jul 2010 11:46
Check to see if they are identical. If one has more lift than it is the intake. If they are the same than "it just dont matter".
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Buda
Re: GPZ cams
17 Jul 2010 12:02
Cool thanks Otto
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
10.25 to 1 comp
K&N pods
GPZ cams
- Mark Wing
Re: GPZ cams
17 Jul 2010 14:07
The exhaust cam should have a section on it that the tach drive gear is ground in but it's smooth with no teeth.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- otakar
Re: GPZ cams
17 Jul 2010 14:11
My pleasure. I mix and match cams all the time. I always like a setup that has lest exhaust than intake. This will sacrifice a bit of your top end but will give you more lower and mid range torque. On my bike that i built I have two different cams of two different manufacturers. The intake is a .420 lift of 270* @.050 duration and the exhaust is a .410 lift with a 252* @.050 duration.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
Re: GPZ cams
17 Jul 2010 14:13
Mark Wing wrote:
He is talking about GPz1100 cams and there was no tach drive on those bikes. The tach was taken off of the coil.
Mark
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Mark Wing
Re: GPZ cams
17 Jul 2010 16:23
otakar wrote:
No I'm talking about 750 cams
Mark Wing wrote:The exhaust cam should have a section on it that the tach drive gear is ground in but it's smooth with no teeth.
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- larrycavan
Re: GPZ cams
20 Jul 2010 04:15 - 20 Jul 2010 04:16
I'm pretty sure the tach drive boss is still on the cam, it's jut not cut into a worm gear. In fact, the photo looks like an exhaust cam.
Last edit: 20 Jul 2010 04:16 by larrycavan.
- otakar
Re: GPZ cams
20 Jul 2010 05:23
The "tach drive boss" is on moth cam shafts. weather cut or uncut. On the GPz1100 it is not cot on either cam.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
Re: GPZ cams
20 Jul 2010 05:26
Mark Wing wrote:
I would not know about the 650/750 since i do not own one of those.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- larrycavan
Re: GPZ cams
20 Jul 2010 05:59
otakar wrote:
Intake cams with that much duration work best with motors that have racing compression and/or big cubic inches.
I've seen an awful lot of bracket bikes go significantly quicker by swapping out long duration intakes for short duration.
Street use, street compression, no big block....less equal better all around performance...
JMO
JMO
