83-84 GPZ 1100 cams
  • Buda
  • Buda's Avatar Topic Author
83-84 GPZ 1100 cams
17 Jul 2010 10:53 - 21 Jul 2010 17:06
#383330
How do I tell the intake from the exhaust cam?
One has r1 stamped on and the other has r6. Does it even mater?
Thanks
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Last edit: 21 Jul 2010 17:06 by Buda.
  • Buda
Re: GPZ cams
17 Jul 2010 11:30
#383338
Anybody..come on guys...help me:)
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
  • otakar
  • otakar's Avatar
Re: GPZ cams
17 Jul 2010 11:46
#383343
Check to see if they are identical. If one has more lift than it is the intake. If they are the same than "it just dont matter".
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Buda
Re: GPZ cams
17 Jul 2010 12:02
#383349
Cool thanks Otto
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
  • Mark Wing
  • Mark Wing's Avatar
Re: GPZ cams
17 Jul 2010 14:07
#383362
The exhaust cam should have a section on it that the tach drive gear is ground in but it's smooth with no teeth.
Mark
Yorba Linda Cal.
  • otakar
  • otakar's Avatar
Re: GPZ cams
17 Jul 2010 14:11
#383363
My pleasure. I mix and match cams all the time. I always like a setup that has lest exhaust than intake. This will sacrifice a bit of your top end but will give you more lower and mid range torque. On my bike that i built I have two different cams of two different manufacturers. The intake is a .420 lift of 270* @.050 duration and the exhaust is a .410 lift with a 252* @.050 duration.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
Re: GPZ cams
17 Jul 2010 14:13
#383364
Mark
He is talking about GPz1100 cams and there was no tach drive on those bikes. The tach was taken off of the coil.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Mark Wing
Re: GPZ cams
17 Jul 2010 16:23
#383397
otakar wrote:
Mark
No I'm talking about 750 cams
Yorba Linda Cal.
  • larrycavan
  • larrycavan's Avatar
Re: GPZ cams
20 Jul 2010 04:15 - 20 Jul 2010 04:16
#384046
I'm pretty sure the tach drive boss is still on the cam, it's jut not cut into a worm gear. In fact, the photo looks like an exhaust cam.
Last edit: 20 Jul 2010 04:16 by larrycavan.
  • otakar
  • otakar's Avatar
Re: GPZ cams
20 Jul 2010 05:23
#384051
The "tach drive boss" is on moth cam shafts. weather cut or uncut. On the GPz1100 it is not cot on either cam.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
Re: GPZ cams
20 Jul 2010 05:26
#384052
Mark Wing wrote:
otakar wrote:
Mark
I would not know about the 650/750 since i do not own one of those.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • larrycavan
Re: GPZ cams
20 Jul 2010 05:59
#384054
Intake cams with that much duration work best with motors that have racing compression and/or big cubic inches.
I've seen an awful lot of bracket bikes go significantly quicker by swapping out long duration intakes for short duration.
Street use, street compression, no big block....less equal better all around performance...
JMO
