timing chain tensioner
- lostkatt
17 Jul 2010 07:28 #383294
by lostkatt
timing chain tensioner was created by lostkatt
I am getting ready to get rid of automatic tensioner and install manual type. How do i make sure that i have TDC on cyclinders so that i dont screw up valve timing.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
17 Jul 2010 07:36 #383296
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic timing chain tensioner
Well lostkatt, what bike/yr are we talking about here?
basically, behind the ignition cover is a spark timing advacner that can be seen thru a hole in the ignition plate. It has a "T" mark on 2 sides of it taht indicate Top Dead Center for either cylinders. These marks can be lined up with the permanent case mark that is also seen thru the ignition plate hole.
Generally the 1 (1-4) "T" mark is lined up with the case mark, and your at Top Dead Center.
Then remove the old tensioner, and install the new one.
Make sure the new tensioner is backed all the way out before mounting to case.
Then turn in BY HAND until it stops just snug/not hard. back off the the bolt about 1/8th of a turn and tighten the lock nut fairly hard but not stripped!
GL!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Old Man Rock
- Thank you received: 225
17 Jul 2010 07:37 #383297
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic timing chain tensioner
Right hand side ignition plate cover...
Using a 17mm socket on most of the KZ's... Rotate clockwise the large nut until you see 1/4 on the "T" mark in reference to the engine case mark....
Now perform your cam timing adjustments...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Thank you received: 2098
17 Jul 2010 09:55 #383315
by Patton
Replied by Patton on topic timing chain tensioner
Old Man Rock wrote:
Excellent pic. Thanks!:kiss:
The advancer is mostly hidden from view behind the large round backing plate.
Here's what the advancer looks like.
This example has the cam style rotor for points.
Dyna-S has a rotor with an embedded magnet instead of a cam.
Oem igniter style rotor has a raised pointed area.
Same advancer may be used with different rotors.
OMR
- Old Man Rock
17 Jul 2010 11:38 #383339
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
17 Jul 2010 11:40 #383340
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
