vacuum leak around carbs
  • gcarson64
  • gcarson64's Avatar Topic Author
15 Jul 2010 19:11
#382951
hello all, i have a problem. i took the carbs off to put a new cam chain tensioner, which was not a problem at all. but then when i put the carbs back on and started it. it ran fine ( WITH NO CAM CHAIN NOISE YAY!! ) but with the exception of the vacuum leak around the base of carbs 2 and 4. i did the starter fluid test to find out which one were the problem. well i took the carbs off again and put some silicon gasket maker on the carb bases ( all of the carbs not just 2 and 4 ). now i am waiting over night for it to dry and then i am goin to see if it fixed the problem. let me know if this is what you would have done. p.s. the bike rain great before, besides the cam chain noise.
1980 kz550 38,500 miles basket case ( soon to be a BOBBER )
1983 kz550 9,600 miles
1988 jeep grand wagoneer 144,500 miles 4 mpg
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: vacuum leak around carbs
16 Jul 2010 01:08
#383015
That is how you deal with air leaks...if that doesn't do it, spring for all new carb holders.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Old Man Rock
  • Old Man Rock's Avatar
16 Jul 2010 05:14
#383036
"silicon gasket maker "... Downfall will be if you ever have to remove those carbs again, guess what....
That's why I use vacuum grease....;)
I'm with Mickey-D.. time for some new manifolds....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • bountyhunter
  • bountyhunter's Avatar
16 Jul 2010 10:32 - 16 Jul 2010 10:35
#383089
Gasoline dissolves silicone so if you get a flooding event, it will eat the stuff up.
That said, I used it too. I take the namifolds off and put a tiny bead around on the face that mates to the head and then use a flat straight edge (popsicle stick) to scrape most of it off evenly and leave just a thin film. Then let it dry fully and install.
Last edit: 16 Jul 2010 10:35 by bountyhunter.
  • TerryK
  • TerryK's Avatar
16 Jul 2010 14:41
#383158
Silicone will dissolve over time. Do it the right way and buy the new flanges.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • gcarson64
16 Jul 2010 20:34
#383248
thanks, i did drive the bike today and it works GREAT. i will order some new manifolds too.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
17 Jul 2010 06:59
#383284
Permatex moto-seal or #2 sealer are both gasoline impervious, and seal very well with just a thin film applied to both halves.
I just put a dab on my finger, then rub it around the surface and tack it up before installing.
Never had an airleak again on several bikes going on a couple years now.
GL.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
