Problems Starting Z1 (KZ1000)
- hocbj23
- Visitor
- Soulmighty
- MFolks
- Thank you received: 540
I use either NGK B8ES or Denso W24-ESU sparkplugs gapped .028"-.032"
Don't let the egine idle excessively as it will overheat. It helps when doing running tune ups(like carb sync.) to position a fan for cooling.
- Soulmighty
- Thank you received: 2098
I got the bike started and it turned out to be the IC Ignitor not having a lead tied to the - pole on the battery. Now it appears I have another problem. The engine got so hot that the 500+ degree engine enamel burnt right off the header only on cyliner 1, 2 and 3.. Cylinder 4 remained fairly cool in comparison with enamel intact. The left side of the engine got considerably hotter than the right. I have no idea what the problem could be. Cylinder out on 4? Jets too small? Please help if you can.. Thanks in advance!
Would use timing light to assure the advancer is properly functioning.
Should see it quickly move back and forth as rpm is varied by blipping the throttle.
The advancer may require lubing and possibly both cleaning and lubing.
Cylinder #4 is likely failing to combust, for whatever reason.
I don't yet suspect an issue regarding pilot jet size.
- hocbj23
- Visitor
- Soulmighty
If anyone could give me an idea of what could cause the engine to heat up so fast, please let me know. I changed the oil twice and flushed the engine the first time I changed the oil. The engine still seems like it's getting too hot.
Help!
Thanks,
- PLUMMEN
- Thank you received: 104
- MFolks
Water flashes to steam at 212F/100C(much safer than touching the pipes).
...flushed the engine the first time I changed the oil....
:huh:
...Could 3 out of 4 cylinders firing cause the engine to get too hot?....
Nope.
- Soulmighty
