- Thank you received: 6
Quick Question on Compression Tests
- Link14
14 Jul 2010 21:28 #382768
by Link14
Quick Question on Compression Tests was created by Link14
Well, I finally got the engine timed and shimmed on the 900 and will be putting the cam cover on tomorrow. I'd like to do a compression test without the carbs or exhaust attached. I can't see any issues with doing that, but I thought I'd check.
Thanks for the help.
Link
Link
- Thank you received: 2098
14 Jul 2010 21:35 #382770
by Patton
Replied by Patton on topic Quick Question on Compression Tests
It will work just fine.
And won't have to worry about holding the throttle wide open while testing. :lol:
- JMKZHI
- Thank you received: 48
15 Jul 2010 06:32 - 15 Jul 2010 06:32 #382809
by JMKZHI
Replied by JMKZHI on topic Quick Question on Compression Tests
The best time to check compression is when the carbs are off the bike, since you won't have to fiddle w the throttle. Exhaust on or exhaust off doesn't matter, since either way the exhaust ports are open to atmosphere.
Last edit: 15 Jul 2010 06:32 by JMKZHI.
- Link14
15 Jul 2010 11:29 #382853
by Link14
Replied by Link14 on topic Quick Question on Compression Tests
Thanks guys!
