APE cam chain tensioner ???
- gcarson64
13 Jul 2010 18:53 #382404
by gcarson64
1980 kz550 38,500 miles basket case ( soon to be a BOBBER )
1983 kz550 9,600 miles
1988 jeep grand wagoneer 144,500 miles 4 mpg
APE cam chain tensioner ??? was created by gcarson64
i am thinking about getting an APE tensioner. but am wondering how you get the right amount of tension without over tightening it. this might be simple but i have no info on how to do this. so please help me if you can. thanks.
- hocbj23
- Visitor
13 Jul 2010 19:06 #382408
by hocbj23
Replied by hocbj23 on topic APE cam chain tensioner ???
They have instructions with them that are pretty clear.However, I just installed one and the way I did it was take the cam cover and ignition cover off,rotate the crank until the bike was at TDC,remove the old tensioner,install the new APE one tighten it down as tight as I could get it WITH MY FINGERS,then rotated the crank 3x checking the cam chain tension,valve positions and timing mark each time and adjusting if necessary,then tightening the lock bolt.Bike fired right up,no valve rattle or chain slap and runs like a top.Little extra work,but worth it IMO.bj
- PLUMMEN
- Thank you received: 104
13 Jul 2010 19:14 #382414
by PLUMMEN
Replied by PLUMMEN on topic APE cam chain tensioner ???
why do you want to install a new one?
- gcarson64
13 Jul 2010 21:12 #382444
by gcarson64
Replied by gcarson64 on topic APE cam chain tensioner ???
the auto tensioner on the bike now is starting to go bad. it sounds like pop tabs rattling around inside the engine
