Engine help
- Paddy3652
13 Jul 2010 09:15 #382262
by Paddy3652
Engine help was created by Paddy3652
I have a 1978 kz650 not too sure wich model it is but I received the bike two years ago and the bike was in such rough shape that i just decided to not even try to start it and just tear it apart and rebuild but then found out that you cant buy the 650 pistons for that year brand new anymore so I when to this Jap bike bone yard that we have here in Regina Saskatchewan Canada and the guy asked me the year and what it was looked in his book and told me that the pistons and rings have been discontinued. He then told me that I could bore the cylinders out however many millimeters and make it a 750. Which I have no problems with but I would like to know what book he looked in because I would need to know more than just how much to bore the cylinder out cause now I have to change alot of parts and this book he has must tell you what you have to do for the rest of the parts is you change and go to a bigger piston. Any help would be greatly appreciated.
- Old Man Rock
- Thank you received: 225
13 Jul 2010 09:27 #382264
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Engine help
As pretty much others have mentioned.... KZ650 pistons/ rings hard to come buy....
Dynoman out of Texas (Speak with Buzz) has other kits.... 700cc kits (pistons, rings, pins, clips & gaskets) Cylinder Boring only....
www.dynoman.net/engine/pistons/kawa.html#650
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Thank you received: 2829
13 Jul 2010 10:07 #382266
by 650ed
Replied by 650ed on topic Engine help
According to Kawasaki.com the STD rings (part # 13008-059) are available. NOS standard pistons are almost always available on eBay. I don't believe you can bore a 650 engine to 750 CC's and still have any cylinder liners left. I would question that this guy actually had a "book" that gave the information he was feeding you. If he did, he should be willing to give its title, publisher, and print date. I take it he didn't actually show you the book? BTW, if you can show a pic of your bike we may be able to identify the model. Ed
- krazinite2003
13 Jul 2010 10:13 #382267
by krazinite2003
i have two 1983 kz750 L3
Replied by krazinite2003 on topic Engine help
hey paddy i think i know who you are talking about i think ebay is in your future lol i am in regina as well its hard to find parts around here
- Paddy3652
13 Jul 2010 15:44 #382353
by Paddy3652
Replied by Paddy3652 on topic Engine help
so if I was to go to the 700cc then are you able to use same crank, cam oil pump and stuff like that I mean this guy told me that he had lots of parts that I could swap out but I mean I dont understand where he is coming from because all my parts look in good shape except the oil pump and pistons
- Joe Fabulous
13 Jul 2010 16:26 - 13 Jul 2010 16:28 #382363
by Joe Fabulous
2004 Harley Davidson Softail
1981 Z1000 Chop
1982 KZ1100 A2
XS 650 Plunger Chop (in bits)
Replied by Joe Fabulous on topic Engine help
Before you take drastic measures, contact Z Power in Leigh, Lancashire UK. They are Kawasaki gods and are one of the only authorised parts only dealers. I was looking for a really out of date factory manual and actually contacted Kawasaki UK to see if they had one, they didn't they but pointed me in the direction of Z Power and they said......how many do you want?
They have a website www.z-power.co.uk well worth a try for all those bits that no one else has or says you can't get.
As for boring out the cylinders, they won't go to 750, 720 is as big as it gets and Wiseco do a piston kit for that.
1981 Z1000 Chop
1982 KZ1100 A2
Last edit: 13 Jul 2010 16:28 by Joe Fabulous.
- krazinite2003
14 Jul 2010 07:20 #382514
by krazinite2003
you could also go to fast cycle sled 352-5533 they used to own northgate kawasaki many years ago here in regina
- Kawickrice
- Thank you received: 18
14 Jul 2010 07:54 - 14 Jul 2010 07:55 #382520
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic Engine help
You can put 750 barrels on a 650 block and be done with it. You will have to clearence the bottom of the barrels slightly to mate to the block. The 650 and 750 four blocks use the same cases and internals. You could even go one up and bore the 750 barrels to 810cc's. If you do that I would use the 750 head also because they flow more than the 650 heads. A few members here have 810cc 650's
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
Last edit: 14 Jul 2010 07:55 by Kawickrice.
- steell
14 Jul 2010 08:58 #382570
by steell
Well, kinda/sorta
A 650 that has no kick starter (81-82 and newer) is the same as the 750 motor with smaller displacement. If the 650 has a kick starter then it has a roller cam chain instead of the HyVo type cam chain of the later models and the 750's.
83-85 Zx750A (GPz750) head and block will work on the later 650's that don't have a kick starter, but not on the earlier 650's.
80-83 KZ750E and KZ750H cylinder blocks and heads have provisions for the roller chain used on the early 650's.
I've got lot's of 750 four parts
Replied by steell on topic Engine help
Well, kinda/sorta
