Fixing a broken fin on the head?
  • supercharged
  • supercharged's Avatar Topic Author
12 Jul 2010 20:46
#382134
Seeking help - As I was lining up parts for another project and received a used J model head in the mail. Opened the box and there it was... the last of the parts needed, only to find a piece of the corner fin broken off and in the box. Don't know if the shipper knew is was broken or if it was actually broken in shipment....
In any case, is there a decent fix for this? I have the head a the broken piece.
Images here
picasaweb.google.com/110972049676614142955/135_0710#
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport... eahhh not so good
- 1988 KZ1000 Police - 50K miles
- 1978 KZ1000 LTD - should be a quick project
- 2001 KZ1000 Police - 30K miles - chromed Sgt Bike GREAT SHAPE
  • kzmk2
  • kzmk2's Avatar
Re: Fixing a broken fin on the head?
12 Jul 2010 20:56
#382137
I would take the head and fin to the best aluminum welder you can find. The welder will probably want to grind a light "v" in the bottom half of the joint for a good weld. Weld from the bottom so it can be sanded smooth after welding. If you have a skilled welder do this you will never be able to tell it was broken off.
  • APE Jay
  • APE Jay's Avatar
12 Jul 2010 21:20
#382145
Where you located?
  • supercharged
12 Jul 2010 23:43
#382200
Jay, I'm in Camarillo. I can surely bring it to you if you have a solution... if the solution is more reasonable then searching for another head.
BTW, I was up at your shop with the Vetter bike while at WSR, but it was like meeting George Bush when i asked to see you :) Actually you were working a system and the guys up front were plenty helpful.
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
  • zed1015
  • zed1015's Avatar
13 Jul 2010 00:45
#382202
Any good welder will be able to tig that back on.
You won't see the join especially as luckily it's a lower fin.
I've even used lumiweld for doing this(only need a blowtorch or oxt/acet)and it gives good strong results.
  • MDawnz1
  • MDawnz1's Avatar
13 Jul 2010 22:29
#382459
Not a problem,
A GOOD motorcycle salvage yard does it all the time.
$25.00 and several minutes,
Including blasting to make it blend,
And you are on your way home.
I have seen wonders done,,,,,,,
Can you say ALL the fins ground off of one side on the Sunday morning ride.
And repaired by the next weekend.
A GREAT welder is a great welder,
Sorry to say I'm just still good.
1974 Z1a, still 903
  • APE Jay
  • APE Jay's Avatar
13 Jul 2010 23:25
#382478
Closer to you. A1 Weldors in North Hollywood. Jim is a master at that very fix. We use him for that. Tell him I said to call.
Jay
  • supercharged
14 Jul 2010 13:12
#382648
thanks for the input. Will look up A1.
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
